I'm seeing both in the upstream docs but haven't sorted out if they're
basically the same or if there is some subtle difference. e.g., overall the
topic is Remote Management, but I also see things like this:
remote_execution_fallback_proxy: Search the host for any proxy with Remote
Execution, useful when the host has no subnet or the subnet does not have
an execution proxy.
Remote Management and Remote Execution are the same thing (we don't use Remote Management for anything else). We use remote execution mostly in upstream, as it's the name of the plugin that provides it. We used the "execution" as part of the name to set clearly the expectations for the plugin.
– Ivan
----- Original Message -----
> Are these the same thing?
> an execution proxy.
> Thanks
> "foreman-dev" group.
> email to foreman-dev+unsubscribe@googlegroups.com.
Seems like the name has migrated from Remote Managment -> Remote Execution.
– bk
> -- Ivan
>> an execution proxy.
>> Thanks
ok I'll go with Remote Execution and hope there a no violent objections
from anywhere.
Thanks
> Execution.
> -- bk
> plugin.
> > -- Ivan
> the
> Remote
> have
> >> an execution proxy.
> >> Thanks
> Groups
> an
> >> email to foreman-dev...@googlegroups.com .
