This is from a recent message I sent to the libvirt-users mailing list
with no responses…maybe someone who uses Foreman has come across
this. Any help troubleshooting is greatly appreciated. Still at the
phase of testing the URI to add to Foreman.
-----------------------I’m attempting to remote connect to my KVM instance using virsh, but
all the commands hang.
When issuing the below command, nothing on the remote system happens,
and no errors are displayed, (hostname changed)
$ virsh --debug 5 --log /var/lib/foreman/virsh.log -c qemu+ssh://
foreman@kvmhost.tld:16509/system?no_tty=1
This is the uncommented lines in /etc/libvirt/libvirtd.conf
listen_tls = 0
listen_tcp = 1
listen_addr = "<omitted, set to management NIC>"
log_level = 1
log_filters="1:remote 1:event 1:qemu"
log_outputs=“1:syslog:libvirtd 1:file:/var/log/libvirt/libvirtd.log”
This is the only debug output I get in /var/log/libvirt/libvirtd.log
during the remote connection attempt
17:56:04.579: debug : virEventRunOnce:595 : Poll got 1 event
17:56:04.580: debug : virEventDispatchTimeouts:405 : Dispatch 3
17:56:04.580: debug : virEventDispatchHandles:450 : Dispatch 10
17:56:04.580: debug : virEventDispatchHandles:464 : i=0 w=1
17:56:04.580: debug : virEventDispatchHandles:464 : i=1 w=2
17:56:04.580: debug : virEventDispatchHandles:464 : i=2 w=3
17:56:04.580: debug : virEventDispatchHandles:464 : i=3 w=4
17:56:04.580: debug : virEventDispatchHandles:464 : i=4 w=5
17:56:04.580: debug : virEventDispatchHandles:464 : i=5 w=6
17:56:04.580: debug : virEventDispatchHandles:464 : i=6 w=7
17:56:04.580: debug : virEventDispatchHandles:464 : i=7 w=8
17:56:04.580: debug : virEventDispatchHandles:477 : Dispatch n=7 f=13
w=8 e=1 0x1629640
17:56:04.580: debug : virEventAddHandleImpl:113 : Add handle fd=20
events=1 cb=0x4196e0 opaque=0x1629640
17:56:04.580: debug : virEventInterruptLocked:664 : Skip interrupt, 1
-1447459072
17:56:04.580: debug : virEventDispatchHandles:464 : i=8 w=9
17:56:04.580: debug : virEventDispatchHandles:464 : i=9 w=10
17:56:04.580: debug : virEventCleanupTimeouts:495 : Cleanup 3
17:56:04.580: debug : virEventCleanupHandles:536 : Cleanupo 11
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=0 w=1, f=5
e=1
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=1 w=2, f=7
e=1
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=2 w=3, f=14
e=1
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=3 w=4, f=15
e=1
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=4 w=5, f=17
e=25
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=5 w=6, f=18
e=25
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=6 w=7, f=19
e=25
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=7 w=8, f=13
e=25
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=8 w=9, f=12
e=25
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=9 w=10, f=11
e=25
17:56:04.580: debug : virEventMakePollFDs:373 : Prepare n=10 w=15,
f=20 e=1
17:56:04.580: debug : virEventCalculateTimeout:314 : Calculate expiry
of 3 timers
17:56:04.580: debug : virEventCalculateTimeout:344 : Timeout at 0 due
in -1 ms
17:56:04.580: debug : virEventRunOnce:593 : Poll on 11 handles
0x7f35a4001240 timeout -1
I’ve already opened up the firewall for port 16509, and allowed the
user foreman (member of libvirt_admin) to manage libvirt via PolicyKit
Relevant line in iptables,
5 ACCEPT tcp – 0.0.0.0/0 0.0.0.0/0 tcp
dpt:16509
/etc/polkit-1/localauthority/50-local.d/50-libvirt-remote-access.pkla
[libvirt Remote Access]
Identity=unix-group:libvirt_admin
Action=org.libvirt.unix.manage
ResultAny=yes
ResultInactive=yes
ResultActive=yes
Originally I had created the file /etc/polkit-1/localauthority/50-
local.d/51-libvirt-foreman-remote-access.pkla with contents below, and
had the file 50-libvirt-remote-access.pkla only allowing a single
user.
/etc/polkit-1/localauthority/50-local.d/51-libvirt-foreman-remote-
access.pkla
[libvirt Foreman Remote Access]
Identity=unix-user:foreman
ResultAny=yes
ResultInactive=yes
ResultActive=yes
However I wasn’t able to connect to libvirt on the host itself, and
the logs indicated it was a PolicyKit block, so my second problem/
question…Is it possible to have multiple local PolicyKit *.pkla
files or can only one exist? From the documentation here,
http://wiki.libvirt.org/page/SSHPolicyKitSetup, it seems like so long
as the names are unique then multiple would be allowed. Reason that’s
key is I’m using Puppet and will have multiple servers/applications
needing access and being restricted to a single file to manage will be
a problem.
Connecting locally with a specific pkla for “foreman”…
$ virsh -c qemu:///system
error: authentication failed
error: failed to connect to the hypervisor
17:50:06.102: debug : virRunWithHook:914 : Command stderr: Not
authorized.
17:50:06.103: error : remoteDispatchAuthPolkit:3810 : Policy kit
denied action org.libvirt.unix.manage from pid 29640, uid 503, result:
256
Thanks
- Trey
