I submitted a PR to rename hosts to systems and hostgroups to system_groups in the routes and the UI. I plan to update the /api routes as well but wanted to get some feedback first.
https://github.com/theforeman/foreman/pull/1034
The routes changes were easy:
- resources :hosts, :path => :systems do
- resources :hostgroups, :except => [:show] do
- resources :hostgroups, :path => :system_groups, :except => [:show] do
This leaves all named URL helper paths the same, so the code doesn't need to change. hosts_paths now goes to /systems and hostgroups_path now goes to /system_groups
All works fine but now the legacy paths /hosts and /hostgroups do not exist. Legacy routes are a "nice to have" for the UI but a "must have" for the API. In order to keep the legacy routes there are two options
- Add redirect routes
- Add legacy routes
Redirect routes as defined as the example below:
get '/hosts', to: redirect('/systems')
This works fine for GET requests, but does not work for POST/PUT/DELETE, so this is not an option for the API.
I choose to use legacy routes with :as => which changes the name path URL helpers to avoid any clashes with the existing routes.
I added a separate file called config/routes/legacy_routes.rb
It contains the resources that were changed in routes.rb using :path =>, and instead I added :as =>
- resources :hosts, :as => :old_hosts do
This creates the 7 RESTful (legacy) routes for /hosts and /hosts/:id and creates named path URL helpers such as old_hosts_path, edit_old_host_path(host), etc, which are NOT used in the code, so they won't clash with the real helpers hosts_path, edit_host_path(host), etc.
Questions
- Do people see this as the right approach to maintain separate separate legacy routes?
- Should API v1 be updated with the new route names and maintain legacy routes, or just leave v1 as is without changing the route names?
- Should API v2 have new and legacy routes or just new routes with no legacy routes, since it hasn't been released yet and can still have breaking changes?
- I also renamed several other paths in the PR for the routs to better match the UI. Should these changes also be included?
/config_tempates --> /provisioning_templates
/ptables --> /partion_tables
/puppetclasses --> /puppet_classes
/lookup_keys --> /smart_variables
/common_parameters --> /global_parameters
/operatingsystems --> /operating_systems
/media --> /installation_media
/models --> /hardware_models
/usergroups --> /user_groups
Regards,
Joseph
What's the background info about the motivation for this name change?
> - resources :hosts do
> + resources :hosts, :path => :systems do
> + resources :hostgroups, :path => :system_groups, :except => [:show] do
> 1) Add redirect routes
> 2) Add legacy routes
> + resources :hosts, :as => :old_hosts do
> Questions
> 1. Do people see this as the right approach to maintain separate separate legacy routes?
> 2. Should API v1 be updated with the new route names and maintain legacy routes, or just leave v1 as is without changing the route names?
> 3. Should API v2 have new and legacy routes or just new routes with no legacy routes, since it hasn't been released yet and can still have breaking changes?
> 4. I also renamed several other paths in the PR for the routs to better match the UI. Should these changes also be included?
> Regards,
> Joseph
> You received this message because you are subscribed to the Google Groups "foreman-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
> For more options, visit https://groups.google.com/groups/opt_out.
> From: "Aaron Stone" <sodabrew@gmail.com>
> To: foreman-dev@googlegroups.com
> Sent: Monday, November 18, 2013 12:25:03 AM
> Subject: Re: [foreman-dev] renaming: hosts to systems and hostgroups to system_groups
Katello uses the terms systems / system groups. Katello is now part of the Foreman project as a plugin/engine. Several objects for both projects overlap (users, roles, environments, organizations, systems, system groups).
Ohad wanted see a PR of a the changes required for Foreman UI/API to use systems / system groups while still keeps the legacy names hosts / host groups.
There is no decision yet whether this PR will be merged or not. It's just a spike.
Joseph
----- Original Message -----
This leaves all named URL helper paths the same, so the code doesn’t need
to /system_groups
exist. Legacy routes are a “nice to have” for the UI but a "must have"
- Add legacy routes
get ‘/hosts’, to: redirect(’/systems’)
won’t clash with the real helpers hosts_path, edit_host_path(host), etc.
Questions
legacy routes?
legacy routes, since it hasn’t been released yet and can still have
breaking changes?
Regards,
Joseph
Thanks for picking this up Aaron!
Last week, a few of us got together to discuss how to move forward
with Katello integration efforts.
One of the topics identified was that we have different terms for
similar things, and similar names for different things, for example:
Host vs System
Puppet Environment vs Lifecycle envionment
Hostgroup vs System group.
Normally, renaming things is a huge pain, and should be avoided unless
really required, some of us thought that the term system actually is
more applicable these days for systems management, therefor we've
agreed to try (e.g. couple of days effort) and understand what is the
actual impact to foreman and its users.
The goals that we've defined are:
- Change all references from Host to System, Hostgroup to System
Definition(?), config_templates to provisioning templates etc.
- Update the API to reflect that, but make sure its 100% compatible
with older API usage (e.g. nothing breaks)
- Consider changing the code objects as well (e.g. was not sure if we
want to change Host::Managed to System::Managed for example).
Hope this helps,
Discussion please
Thanks
Ohad
>> Questions
>> Regards,
>> Joseph
Aaron,
I updated the PR to say "DO NOT MERGE" to make it more clear.
Joseph
> From: "Joseph Magen"
> Sent: Monday, November 18, 2013 9:14:26 AM
> > From: "Aaron Stone"
> > system_groups
> groups.
> spike.
> Joseph
> > > system_groups
> > > to /system_groups
> > > so
> > > Questions
> > > legacy routes?
> > > breaking changes?
> > > Regards,
> > > Joseph
