Repo for foreman having issues? CentOS 7 new install, trying to setup new
foreman installation, did this the past several times no issues. Only repo
on this system that is having the issue is the one below. The initial RPM
I had to download and install as local. commands such as # yum install
foreman-installer of course fail. Per the 1.7 manual documentation this is
the correct repo and url specification. As you can see, the other repos
configured on this Linux system seem to be fine, it is only the foreman
repo that is failing.
[root@foreman ~]# yum repolist
Loaded plugins: fastestmirror
http://yum.theforeman.org/releases/1.7/el7/x86_64/repodata/repomd.xml:
[Errno 12] Timeout on
http://yum.theforeman.org/releases/1.7/el7/x86_64/repodata/repomd.xml: (28,
'Connection timed out after 30182 milliseconds')
Trying other mirror.
'Connection timed out after 30031 milliseconds')
'Connection timed out after 30184 milliseconds')
'Connection timed out after 30032 milliseconds')
'Connection timed out after 30033 milliseconds')
'Connection timed out after 30183 milliseconds')
'Connection timed out after 30181 milliseconds')
http://yum.theforeman.org/plugins/1.7/el7/x86_64/repodata/repomd.xml:
http://yum.theforeman.org/plugins/1.7/el7/x86_64/repodata/repomd.xml: (28,
repo
id
repo
name
status
base/7/x86_64
CentOS-7 -
Base
8,465
epel/x86_64
Extra Packages for Enterprise Linux 7 -
x86_64 7,393
extras/7/x86_64
CentOS-7 -
Extras
104
foreman/x86_64
Foreman
1.7
0
foreman-plugins/x86_64
Foreman plugins
1.7
0
puppetlabs-deps/x86_64
Puppet Labs Dependencies El 7 -
x86_64
17
puppetlabs-products/x86_64
Puppet Labs Products El 7 -
x86_64
138
updates/7/x86_64
CentOS-7 -
Updates
1,723
repolist: 17,840
[root@foreman ~]#
