Hi all,
I'm working on an install of Puppet and Foreman however the dashboard
is showing that none of my hosts are in sync (something which I know
to be false!)
I'm running Puppet-server 0.25.4 and the reports are being created (in
YAML Format at least!) in the correct directory.
Reporting is enabled for both logs and foreman and the ruby report is
in the correct directory, however the URL http://foreman:3000/reports/create/?format=yml
does not appear to exist, even though foreman is running on port 3000
(or at least the main web interface is!)
Does any one know if this is a bug that I've found or if this is
expected behaviour for foreman 0.1.3?
Thanks in advance,
PF.
does your host foreman resolve anything?
if its a local install, change it to localhost of fqdn of your real server
name.
btw: there is no need to store the reports locally for Foreman.
cheers,
Ohad
On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken wrote:
Hi all,
I’m working on an install of Puppet and Foreman however the dashboard
to be false!)
I’m running Puppet-server 0.25.4 and the reports are being created (in
Does any one know if this is a bug that I’ve found or if this is
Thanks in advance,
PF.
"Foreman users" group.
foreman-users+unsubscribe@googlegroups.comforeman-users%2Bunsubscribe@googlegroups.com
Hi Ohad,
I can visit http://foreman.domain.tld:3000/ in a browser and I get
presented with the dashboard and all the other links work.
It's only when I try and access the /reports/create/?format=yml in the
browser that I get a 404.
I have just checked the foreman.rb and noticed that it was pointing to
the foreman server's FQDN, not the actual URL (foreman.domain.tld)
that we're running it under, however as I get the 404 in the browser,
I'm still not convinced that resolution is the issue (although I'm
happy to be proved wrong!)
Cheers,
PF
> name.
> cheers,
> Ohad
>> Hi all,
>> to be false!)
>> Thanks in advance,
>> PF.
>> To post to this group, send email to foreman-users@googlegroups.com.
>> foreman-users+unsubscribe@googlegroups.com.
when you use your browser, you perform an http get operation, the report is
post, therefor you get the error in the browser
Ohad
On Thu, Mar 4, 2010 at 9:12 PM, Matthew Macdonald-Wallace < mattmacwall@gmail.com> wrote:
Hi Ohad,
It’s only when I try and access the /reports/create/?format=yml in the
the foreman server’s FQDN, not the actual URL (foreman.domain.tld)
that we’re running it under, however as I get the 404 in the browser,
I’m still not convinced that resolution is the issue (although I’m
Cheers,
PF
server
name.
cheers,
Ohad
On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken mattmacwall@gmail.com > wrote:
Hi all,
to be false!)
Thanks in advance,
PF.
Groups
“Foreman users” group.
ah, that makes sense.
I'll have to wait for the next puppet run and see what I get!
M.
On 4 March 2010 13:15, Ohad Levy wrote:
> Hi,
> post, therefor you get the error in the browser :)
> Ohad
> On Thu, Mar 4, 2010 at 9:12 PM, Matthew Macdonald-Wallace > wrote:
>> Hi Ohad,
>> Cheers,
>> PF
>> > server
>> > name.
>> > cheers,
>> > Ohad
>> > On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken >> > wrote:
>> >> Hi all,
>> >> to be false!)
>> >> Thanks in advance,
>> >> PF.
>> >> Groups
>> > Groups
OK, the run has just completed (according to the logs) and although
there are no errors from Foreman as far as I can see, The dashboard is
still reporting that all hosts are out of sync and the "run
distribution" graph is still showing that no clients have run.
Any ideas?
PF
> M.
>> Hi,
>> Ohad
>> On Thu, Mar 4, 2010 at 9:12 PM, Matthew Macdonald-Wallace >> wrote:
>>> Hi Ohad,
>>> Cheers,
>>> PF
>>> > server
>>> > name.
>>> > cheers,
>>> > Ohad
>>> > On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken >>> > wrote:
>>> >> Hi all,
>>> >> to be false!)
>>> >> Thanks in advance,
>>> >> PF.
>>> >> Groups
>>> > Groups
please check the puppetmater logs, to be sure that foreman log has been
processed, additionally have a look at foreman logs (logs/production.log) to
see if you can see any errors.
my guess is that the puppet foreman report is not in the right place or that
its not pointing to the right url.
cheers,
Ohad
On Thu, Mar 4, 2010 at 9:24 PM, Matthew Macdonald-Wallace < mattmacwall@gmail.com> wrote:
still reporting that all hosts are out of sync and the “run
distribution” graph is still showing that no clients have run.
Any ideas?
PF
On 4 March 2010 13:19, Matthew Macdonald-Wallace mattmacwall@gmail.com > wrote:
I’ll have to wait for the next puppet run and see what I get!
M.
is
Ohad
On Thu, Mar 4, 2010 at 9:12 PM, Matthew Macdonald-Wallace > >> mattmacwall@gmail.com wrote:
Hi Ohad,
Cheers,
PF
server
name.
cheers,
Ohad
On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken mattmacwall@gmail.com > >>> > wrote:
Hi all,
dashboard
to be false!)
(in
is
3000
Thanks in advance,
PF.
Groups
Groups
Groups
Groups
ok, I've checked and when the server was running 0.24.x under RACK
foreman reporting was working without issue. Now that it's running
0.25.x it's not running the foreman reports.
I'll ask on the Puppet list.
Thanks for all your help.
PF
> cheers,
> Ohad
>> Any ideas?
>> PF
>> > M.
>> >> Hi,
>> >> report is
>> >> Ohad
>> >> On Thu, Mar 4, 2010 at 9:12 PM, Matthew Macdonald-Wallace >> >> wrote:
>> >>> Hi Ohad,
>> >>> Cheers,
>> >>> PF
>> >>> > server
>> >>> > name.
>> >>> > cheers,
>> >>> > Ohad
>> >>> > On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken >> >>> > wrote:
>> >>> >> Hi all,
>> >>> >> dashboard
>> >>> >> know
>> >>> >> to be false!)
>> >>> >> (in
>> >>> >> is
>> >>> >> 3000
>> >>> >> Thanks in advance,
>> >>> >> PF.
>> >>> >> Groups
>> >>> > Groups
>> >>> Groups
>> >> Groups
i think you should only have /etc/puppet/puppet.conf and not
puppetmasterd.conf
cheers,
Ohad
On Thu, Mar 4, 2010 at 10:02 PM, Matthew Macdonald-Wallace < mattmacwall@gmail.com> wrote:
ok, I’ve checked and when the server was running 0.24.x under RACK
foreman reporting was working without issue. Now that it’s running
0.25.x it’s not running the foreman reports.
I’ll ask on the Puppet list.
PF
to
that
cheers,
Ohad
On Thu, Mar 4, 2010 at 9:24 PM, Matthew Macdonald-Wallace > > mattmacwall@gmail.com wrote:
Any ideas?
PF
On 4 March 2010 13:19, Matthew Macdonald-Wallace <mattmacwall@gmail.com > > > >> wrote:
M.
report is
Ohad
On Thu, Mar 4, 2010 at 9:12 PM, Matthew Macdonald-Wallace > >> >> mattmacwall@gmail.com wrote:
Hi Ohad,
the
to
browser,
Cheers,
PF
real
server
name.
cheers,
Ohad
On Thu, Mar 4, 2010 at 8:54 PM, Prof Falken < > mattmacwall@gmail.com> > >> >>> > wrote:
Hi all,
dashboard
know
to be false!)
created
(in
report
is
3000
Thanks in advance,
PF.
Google
Groups
Groups
Groups
Groups
Groups
