I have setup a small POC env with foreman and puppet etc
Puppetmaster and Foreman are using the same mysql backend and running
on the same machine.
The puppet clients are successfully dropping off the reports as I can
see them in the logs and in the $REPORTSDIR when store is enabled.
The problem is, the reports fail to show on the foreman fronend…
I have checked the foreman logs and discovered this entry:
Processing ReportsController#create to yml (for x.x.x.x at 2011-12-02
17:01:53) [POST]
Parameters: {"format"=>"yml", "action"=>"create",
"controller"=>"reports", "report"=>"[FILTERED]"}
processing report for s0034sbl3814.x.x.x
Failed to process report for s0034sbl3814.x.x.x due to:undefined
method `allowed_to?' for nil:NilClass
Completed in 6ms (View: 0, DB: 2) | 500 Internal Server Error [http://
S0034SBL3814.x.x.x/reports/create?format=yml]
> hi all,
> 17:01:53) [POST]
> Cant figure out how to resolve it, any ideas?
any chance you removed all of your users from the system? can you try running
rake permissions:reset RAILS_ENV=production
Ohad
On Fri, Dec 2, 2011 at 8:08 AM, MattW wrote:
> Regards
> Matt
> To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
> For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
Thats correct. I tried migrating the sqlite3 DB to the puppet shared
mysql DB using the db:dump/db:load utility mentioned in the wiki but
it failed.
So I reset foreman and pointed it to the mysql production DB.
I have run the "rake permissions:reset RAILS_ENV=production" after
migrating but will giving it another go seems to have rectified the
issue.
I will monitor it throughout the day to see if it continues to work.
Thank You
Regards
Matt
> > hi all,
> > The problem is, the reports fail to show on the foreman fronend....
> > 17:01:53) [POST]
> Ohad
> > Regards
> > Matt
> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
On Dec 5, 9:06 am, MattW wrote:
> Ohad,
> it failed.
> issue.
> Thank You
> Regards
> Matt
> > > hi all,
> > > 17:01:53) [POST]
> > Ohad
> > > Regards
> > > Matt
