Hello everyone,
Disclaimer: I'm complete rookie in terms of
DevOps/app deployment automation.
I looped through TheForeman feature lists and Screenshots and I liked what
I saw. As a "give it a try" momentum I want to test the concept as follows:
- Install TheForeman on virtualbox Ubuntu LTS 12.04
- Use TheForeman to configure, provision and monitor Redmine
application (should be deployed in the EC2)
I followed The Foreman Installer<Foreman :: Manual> installation
notes and it worked like a charm. I have also installed foreman-ec2 and
foreman-compute gems.
Problem
However I struck with step 2. execution/planning. Basically I just don't
understand what should I do next (maybe someone would kindly point me to
some blog/article/piece of documentation?)
What I have done so far:
- Configuration: Added smart-proxy as per Installation document (The
) - Configuration: Defined test environment
- Provisioning: Defined Ubuntu OS Operating system (as derivative of
Debian?, the only option available in the drop-down) - Provisioning: Defined redmine host group
Questions
- I see no Puppet classes available in configuration and import from
local proxy does not give any. I am not sure whether I need any and how to
import those? Should I refer to Puppet project documentation to this? - I see a am able to define EC2 computational resource, however I don't
get how/in which order should I define provisioning templates, what pieces
of configuration (puppet classes etc…) should I use? I would higly
appreciate if someone could point me to complete step-by-step procedure for
any kind of web-app deployment using TheForeman (redmine is my target,
however any other web-app could be a good starting point).
I believe TheForeman entry level isn't that high, however it might be too
high to me
Thanks in advance and kudos for such great piece of software!
–wbr
LM
