> Hi,
> I have created a puppet class for installing a rpm file…but it does not
> work…could you direct me what the problem is…
> init.pp
> class mcafee-rpm {
Note that hyphens aren't permitted in class names, this can cause
strange issues, possibly including the one you're seeing:
http://docs.puppetlabs.com/puppet/latest/reference/lang_reserved.html#classes-and-types
> package { "uvscan":
> provider => 'rpm',
> ensure => installed,
> source =>
> 'http://server1.local/packages/mcafee/uvscan-6.0.3.356-1.0.el6.x86_64.rpm',
> I can install the rpm using
> rpm -Uvh
> when using puppet agent
> Error: Could not retrieve catalog from remote server: Error 400 on
> SERVER: Could not find class mcafee-rpm for server21.local on node
> server21.local
> Warning: Not using cache on failed catalog
> Error: Could not retrieve catalog; skipping run
Puppet's unable to find your init.pp file, perhaps it's in the wrong
directory.
It should be in
/etc/puppet/modules/production/mcafee-rpm/manifests/init.pp or similar
(again, rename the module and class without hyphen).
http://docs.puppetlabs.com/puppet/2.7/reference/modules_fundamentals.html
On 01/03/13 14:38, Binoy Daniel wrote:
Dominic Cleal
Red Hat Engineering
Hi Dominic,
Thanks for the quick response…it works well…
Thanks
Daniel
> > Hi,
> > I have created a puppet class for installing a rpm file..but it does not
> > work..could you direct me what the problem is..
> > init.pp
> > class mcafee-rpm {
> > package { "uvscan":
> > provider => 'rpm',
> > source =>
> > rpm -Uvh
> > server21.local
> directory.
> It should be in
> Dominic Cleal
> Red Hat Engineering
