This had me scratching my head for a bit. I’ve seen this problem before in
the Foreman ecosystem so I figured I’d send an email about it.
I was working on a test and got the following output below. It seemed weird
because it’s a constant and it shouldn’t change (https://git.io/vrqQO). Can
anyone figure out why?
[1] pry(#<listing repositories>)> HammerCLIKatello::RESOURCE_NAME_MAPPING
:system => :content_host,
:environment => :lifecycle_environment
Here’s a hint: https://git.io/vrq77
David
> From: "David Davis" <daviddavis@redhat.com>
> To: foreman-dev@googlegroups.com
> Sent: Thursday, May 12, 2016 12:44:13 PM
> Subject: [foreman-dev] Ruby gotcha with constants and hashes
It didn't "change" depending on how you look at it, object_id of the hash stayed
the same.
----- Original Message -----
[1] pry(#)> HammerCLIKatello::RESOURCE_NAME_MAPPING
David
"foreman-dev" group.
Yes, the value of the hash changed but it retained the same
address/object_id (which I think was the problem: the code assumed it was
getting back a value instead of an object reference).
This was actually caught in hammer-cli-katello by running the MutableConstant
cop <http://www.rubydoc.info/gems/rubocop/RuboCop/Cop/Style/MutableConstant>.
I am thinking it might be a good idea to enable it for other repos. At the
very least, it should speed our code up.
Thoughts?
David
in
weird
Can
It didn’t “change” depending on how you look at it, object_id of the hash
stayed
the same.
David
> Sent: Thursday, May 12, 2016 2:12:56 PM
> Subject: Re: [foreman-dev] Ruby gotcha with constants and hashes
> Thoughts?
+1
Sounds good to me, if it needs to be modified it shouldn't be a constant.
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com > wrote:
in
weird
Can
stayed
the same.
David
Hello
I have mixed feelings about this. I understand the confusion but I don't think
it's too problematic. Constants in Ruby are not really constants anyway. You
can redefine them (getting just warning) unless you're in instance method. I
don't think majority of libraries would follow this cop suggestions so to
remain consistent I'd keep this as is.
I don't have strong opinion on this so If I'm the only one against, feel free
to enable it.
OT: note that classes are also just constants pointing to a singleton objects
(constant starts with capital letter) and you can change (undefine) them,
actually Rails uses this for auto-reloading. With hashes, arrays and other
complex objects I find this as a feature rather than bug, what's more
concerning to me is this
CONST = 'const'
CONST << ' modified'
CONST # => 'const modified'
Marek
MutableConstant cop
http://www.rubydoc.info/gems/rubocop/RuboCop/Cop/Style/MutableConstant. I
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com > > wrote:
in
weird
Can
stayed
the same.
[1] pry(#)>
David
Groups
an
The fact that we’ve already uncovered one problem seems to me like it is a
problem. Also, I’m interested to know why you think modifying string
constants is concerning but not hash or array constants.
David
On Fri, May 13, 2016 at 3:54 AM, Marek Hulán wrote:
Hello
I have mixed feelings about this. I understand the confusion but I don’t
think
it’s too problematic. Constants in Ruby are not really constants anyway.
You
can redefine them (getting just warning) unless you’re in instance method.
I
don’t think majority of libraries would follow this cop suggestions so to
remain consistent I’d keep this as is.
I don’t have strong opinion on this so If I’m the only one against, feel
free
to enable it.
objects
complex objects I find this as a feature rather than bug, what’s more
CONST = 'const’
CONST << ’ modified’
CONST # => ‘const modified’
Marek
MutableConstant cop
I
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com > > > > wrote:
before
in
weird
Can
hash
stayed
the same.
[1] pry(#)>
David
Groups
send
an
Groups
“foreman-dev” group.
an
Wait a second, isn't the constant dup'd?
If so, then the constant should technically be changing, right?
e.g.
2.2.4 :014 > H1 =
{ foo: 'bar', baz: 'qux' }
.freeze
2.2.4 :015 > H1.object_id
=> 122468880
2.2.4 :016 > H2 = H1.dup
2.2.4 :017 > H2.object_id
=> 41286800
2.2.4 :018 > H2[:baz] = "quux"
2.2.4 :019 > H1
=> {:foo=>"bar", :baz=>"qux"}
2.2.4 :020 > H2
=> {:foo=>"bar", :baz=>"quux"}
Andrew Kofink
Software Engineering Intern
Red Hat Satellite 6
akofink@redhat.com
David
On Fri, May 13, 2016 at 3:54 AM, Marek Hulán mhulan@redhat.com wrote:
Hello
think
You
method. I
free
to enable it.
objects
CONST = 'const’
Marek
was
MutableConstant cop
I
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com >> > >> > wrote:
before
in
seemed
weird
Can
hash
stayed
the same.
[1] pry(#)>
David
Groups
send
an
Groups
send an
Should not be changing*
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
On Fri, May 13, 2016 at 9:20 AM, Andrew Kofink wrote:
Wait a second, isn’t the constant dup’d?
e.g.
2.2.4 :014 > H1 =
{ foo: ‘bar’, baz: ‘qux’ }
.freeze
=> 122468880
=> 41286800
2.2.4 :019 > H1
=> {:foo=>“bar”, :baz=>“qux”}
2.2.4 :020 > H2
=> {:foo=>“bar”, :baz=>“quux”}
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
a problem. Also, I’m interested to know why you think modifying string
David
Hello
think
You
method. I
free
to enable it.
objects
other
CONST = 'const’
Marek
was
MutableConstant cop
I
the
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com >>> > >>> > wrote:
before
in
seemed
weird
Can
the hash
stayed
the same.
[1] pry(#)>
David
Groups
send
an
Groups
send an
Yes, that’s correct. Although it might not be clear to developers that you
need to call dup if you assign your constant to a variable or return it
from a method:
[1] pry(main)> MY_HASH = {:a => 1}
:a => 1
[2] pry(main)> some_var = MY_HASH
:a => 1
[3] pry(main)> some_var.object_id
70355561000620
[4] pry(main)> MY_HASH.object_id
70355561000620
[5] pry(main)> some_var[:b] = 2
2
[6] pry(main)> some_var
:a => 1,
:b => 2
[7] pry(main)> MY_HASH
:a => 1,
:b => 2
My fix was in fact to call dup:
https://github.com/Katello/hammer-cli-katello/pull/397
David
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
e.g.
2.2.4 :014 > H1 =
.freeze
=> 122468880
=> 41286800
2.2.4 :018 > H2[:baz] = “quux”
2.2.4 :019 > H1
2.2.4 :020 > H2
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
David
Hello
don’t think
anyway. You
method. I
to
feel free
to enable it.
objects
them,
other
CONST = ‘const’
Marek
was
MutableConstant cop
I
the
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin <stephen@redhat.com >>>> > >>>> > >>>> > wrote:
before
in
seemed
weird
Can
the hash
stayed
the same.
[1] pry(#)>
David
Groups
send
an
Groups
send an
Groups “foreman-dev” group.
an email to foreman-dev+unsubscribe@googlegroups.com.
> From: "Andrew Kofink" <akofink@redhat.com>
> Cc: "Marek Hulán" <mhulan@redhat.com>
> Sent: Friday, May 13, 2016 9:21:45 AM
> Andrew Kofink
> Red Hat Satellite 6
> akofink@redhat.com
That was part of the change that was just merged to fix the tests. In the previous
case, the hash wasn't frozen and passed by reference allowing anybody to change
the (in)constant's value (which is done here[1]).
[1] https://github.com/Katello/hammer-cli-katello/blob/master/lib/hammer_cli_katello/katello_environment_name_resolvable.rb#L10
e.g.
2.2.4 :014 > H1 =
.freeze
=> 122468880
=> 41286800
2.2.4 :019 > H1
2.2.4 :020 > H2
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
On Fri, May 13, 2016 at 8:55 AM, David Davis daviddavis@redhat.com > > wrote:
David
Hello
think
You
method. I
free
to enable it.
objects
other
CONST = 'const’
Marek
was
MutableConstant cop
I
the
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com > >>> > > >>> > wrote:
before
in
seemed
weird
Can
the hash
stayed
the same.
[1] pry(#)>
David
Groups
send
an
Groups
send an
Ah, didn't realize that link already contained the fix.
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
Cc: “Marek Hulán” mhulan@redhat.com
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
previous
case, the hash wasn’t frozen and passed by reference allowing anybody to
change
the (in)constant’s value (which is done here[1]).
[1]
e.g.
2.2.4 :014 > H1 =
.freeze
=> 122468880
=> 41286800
2.2.4 :019 > H1
2.2.4 :020 > H2
Andrew Kofink
Red Hat Satellite 6
akofink@redhat.com
On Fri, May 13, 2016 at 8:55 AM, David Davis daviddavis@redhat.com > > > wrote:
is
David
On Fri, May 13, 2016 at 3:54 AM, Marek Hulán mhulan@redhat.com > wrote:
Hello
don’t
think
anyway.
You
method. I
so to
feel
free
to enable it.
objects
them,
other
CONST = 'const’
Marek
it
was
MutableConstant cop
I
At
the
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin < > stephen@redhat.com> > > >>> > > > >>> > wrote:
problem
before
in
seemed
weird
Can
the hash
stayed
the same.
[1] pry(#)>
David
You received this message because you are subscribed to the
Google
Groups
it,
send
an
Google
Groups
send an
Groups
send an
> problem.
That's fair, I just haven't encountered it myself yet.
I said more concerning
somehow I look at strings as simple data type,
arrays, hashes, structs, sets etc are complex composes of multiple types. But
I understand that there are no primitives, just objects, in Ruby so as long as
object is mutable, it might change even if set as constant.
Anyway, seems no one else has objections and I don't have strong opinion, so
I'll get used to freezing
On Friday 13 of May 2016 08:55:35 David Davis wrote:
Marek
David
Hello
think
You
I
free
to enable it.
objects
CONST = 'const’
Marek
was
MutableConstant cop
I
Thoughts?
David
On Thu, May 12, 2016 at 1:55 PM, Stephen Benjamin stephen@redhat.com > > > > > > wrote:
before
in
seemed
weird
Can
hash
stayed
the same.
[1] pry(#)>
David
Groups
send
an
Groups
an
