Hello All,
Has anyone got foreman UI running under passenger and nginx?. The rack
application doesnt startup with the following config
server {
listen 7000;
server_name foreman;
root /usr/share/foreman/public;
passenger_enabled on;
passenger_use_global_queue on;
rails_spawn_method smart;
rails_env production;
passenger_min_instances 2;
charset utf-8;
access_log logs/foreman/foreman.log;
error_log logs/foreman/foreman_error.log;
Can anyone point me to the configuration?
I have got foreman running under apache + passenger fine.
Regards,
Kevin
> Hello All,
> server {
> listen 7000;
> charset utf-8;
what is the error that you get? are you sure you are running it with the
correct user?
Ohad
> Regards,
> Kevin
I get the following error in nginx logs:
2011/06/18 13:25:00 [error] 22670#0: *1 directory index of "/usr/share/
foreman/public/" is forbidden, client: <ipaddress>, server: foreman,
request: "GET / HTTP/1.1", host: "foreman:7000"
When i enable autoindex on; in the below configuration, i only get a
directory listing on /usr/share/foreman/ dir. Nginx is running as user
nginx. The permission on the /usr/share/foreman dir is with user
foreman.
Regards,
Kevin
> > Hello All,
> > server {
> > listen 7000;
> > charset utf-8;
> correct user?
> Ohad
> > Regards,
> > Kevin
> Has there been any traction on this issue? I'm trying to get a nightly
> build to work with Nginx + Passenger with the same results. It seems to
> work fine in Apache.
> Thats pretty odd, I have little experience with nginx, but are you sure
its configured correctly?
Ohad
On Mon, Jun 4, 2012 at 9:54 AM, Ryan Bourgeois wrote:
2011/06/18 13:25:00 [error] 22670#0: *1 directory index of “/usr/share/
foreman/public/” is forbidden, client: , server: foreman,
request: “GET / HTTP/1.1”, host: “foreman:7000”
foreman.
Regards,
Kevin
Hello All,
rack
server {
listen 7000;
charset utf-8;
error_log logs/foreman/foreman_error.**log;
the
correct user?
Ohad
Regards,
Kevin
"Foreman users" group.
To view this discussion on the web visit
https://groups.google.com/d/msg/foreman-users/-/cCdEGKAAA5gJ.
Yes, I can drop an example config.ru in place and it just works.
On Mon, Jun 4, 2012 at 2:02 AM, Ohad Levy wrote:
On Mon, Jun 4, 2012 at 9:54 AM, Ryan Bourgeois bluedragonx@gmail.comwrote:
Has there been any traction on this issue? I’m trying to get a nightly
Actually, I just figured it out. The above statement wasn't entirely true.
I created a test config.ru and an empty public under /var/www to test my
Foreman nnginx config. I changed the vhost to point the root to /var/www
instead of /usr/share/foreman and it worked. When I pointed the root back
at /usr/share/foreman and copied my example config.ru to /usr/share/foreman
(and left the rest of that directory alone) it no longer worked.
I then overwrote the public symlink with the actual directory (cp
-rf /var/lib/foreman/public /usr/share/foreman/public) and did the same
with the tmp directory and things work as normal.
It appears that Passenger on Nginx does not like those two directories to
be symlinks. My quick googling has not yet turned up a solution to this
other than not using symlinks for your root directory.
I got it working with some minimal hackery. Since I'm deploying this using
Puppet and the nightly builds I'm doing my best to avoid messing with
anything a package deploys, and this hack is minimal enough to satisfy me.
Anywho, I fixed it by symlinking the config.ru under /var/lib/foreman (ln
-s /usr/share/foreman/config.ru /var/lib/foreman/config.ru).
This works because Passenger resolves the real path of the root and then
tries to find config.ru relative to that. So it's looking for a
config.ruat the above location.
Hopefully others who run across this issue will also run across this post.
I'd been banging my head against the wall most of the night to fix it!
Actually, I just figured it out. The above statement wasn’t entirely true.
back at /usr/share/foreman and copied my example config.ru to
/usr/share/foreman (and left the rest of that directory alone) it no longer
worked.
>>>> sure its configured correctly?
>> true. I created a test config.ru and an empty public under /var/www to
>> test my Foreman nnginx config. I changed the vhost to point the root to
>> /var/www instead of /usr/share/foreman and it worked. When I pointed
>> the root back at /usr/share/foreman and copied my example config.ru to
>> worked.
> tries to find config.ru relative to that. So it's looking for a config.ruat the above location.
Thanks Ryan!! any chance you want to patch up the installer[1]
to reflect this change?
Ohad
[1] https://github.com/theforeman/foreman-installer
Sure, I'll see if I can't get something worked up and tested tonight.
-Ryan
nightly build to work with Nginx + Passenger with the same results. It
seems to work fine in Apache.
worked.
to be symlinks. My quick googling has not yet turned up a solution to this
I got it working with some minimal hackery. Since I’m deploying this
using Puppet and the nightly builds I’m doing my best to avoid messing with
(ln -s /usr/share/foreman/config.ru /var/lib/foreman/config.ru).
tries to find config.ru relative to that. So it’s looking for a config.ruat the above location.
post. I’d been banging my head against the wall most of the night to fix it!
Ohad
The foreman-installer uses Apache so it's a non-issue there. It also looks
like it handles the link. Since I'm rolling my own set of manifests around
the nightly build it behaves differently.
-Ryan
On Mon, Jun 4, 2012 at 9:54 AM, Ryan Bourgeois <bluedragonx@gmail.com >>>>>> > wrote:
worked.
config.ru at the above location.
Ohad
Sure, I’ll see if I can’t get something worked up and tested tonight.
-Ryan
