Morning everyone,
I've post this topic on foreman-users list, unfortunately without any
answer.
https://groups.google.com/forum/#!topic/foreman-users/DX7NogwFQzw
if someone can explain me what I'm doing wrong?
To resume:
I'm working with 2 different environments, in both environment I've the
same puppet module, with the same class name but with a different class
parameter value:
Production:
Test_module1:
class test ( $test_version="v1" ) {
Development:
Test_module1:
class test ( $test_version=“v2” ) {
When I ask to the REST API, my parameter ID is the same for all
environments.
https://puppetsrv/api/v2/puppetclasses/86
"id": 86,
"name": "test_module1",
"created_at": "2014-03-19T12:01:34Z",
"updated_at": "2014-03-19T12:01:34Z",
"smart_variables":
"smart_class_parameters":
"parameter": "test_version",
"id": 266
"environments":
"name": "development",
"id": 4
"name": "production",
"id": 1
When I use Foreman to override the parameter value, my default value is
changed on all environment.
How can I manage my class parameter by environment ?
I would like to change my parameter in development environment without
impacted my production, is it possible ?
My environment is the following
RELEASE: Red Hat Enterprise Linux Server release 6.5 (Santiago)
FOREMAN: 1.4.0
RUBY: ruby 1.8.7 (2011-06-30 patchlevel 352) [x86_64-linux]
PUPPET: 3.4.2
Thanks for your help!
Greg
Just a quick check, do you use parser = future in your puppet.conf?
On Mar 24, 2014 10:45 AM, "Grégory Giglio" wrote:
Morning everyone,
I’ve post this topic on foreman-users list, unfortunately without any
answer.
if someone can explain me what I’m doing wrong?
To resume:
I’m working with 2 different environments, in both environment I’ve the
parameter value:
Production:
Test_module1:
class test ( $test_version=“v1” ) {
Development:
Test_module1:
environments.
"id": 86,
"smart_variables":
"id": 266
"environments":
"id": 4
"id": 1
FOREMAN: 1.4.0
PUPPET: 3.4.2
Greg
"foreman-dev" group.
Hello, thanks for asking
No,this key is not defined.
Here is my puppet.conf
[main]
# The Puppet log directory.
# The default value is '$vardir/log'.
logdir = /var/log/puppet
# Where Puppet PID files are kept.
# The default value is '$vardir/run'.
rundir = /var/run/puppet
# Where SSL certificates are kept.
# The default value is '$confdir/ssl'.
ssldir = $vardir/ssl
# Allow services in the 'puppet' group to access key (Foreman + proxy)
privatekeydir = $ssldir/private_keys { group = service }
hostprivkey = $privatekeydir/$certname.pem { mode = 640 }
# Puppet 3.0.x requires this in both [main] and [master] - harmless on
agents
autosign = $confdir/autosign.conf { mode = 664 }
[agent]
classfile = $vardir/classes.txt
localconfig = $vardir/localconfig
default_schedules = false
report = true
pluginsync = true
masterport = 8140
environment = production
certname = puppetsrv
server = puppetsrv
listen = false
splay = false
runinterval = 1800
noop = false
show_diff = false
configtimeout = 120
[master]
reports = foreman
external_nodes = /etc/puppet/node.rb
node_terminus = exec
ca = true
ssldir = /var/lib/puppet/ssl
[development]
modulepath =
/etc/puppet/environments/development/modules:/etc/puppet/environments/common:/usr/share/puppet/modules
config_version =
[production]
modulepath =
/etc/puppet/environments/production/modules:/etc/puppet/environments/common:/usr/share/puppet/modules
config_version =
> On Mar 24, 2014 10:45 AM, "Grégory Giglio" <greg....@gmail.com> > wrote:
>> Morning everyone,
>> answer.
>> To resume:
>> parameter value:
>> Production:
>> Test_module1:
>> Development:
>> Test_module1:
>> class test ( $test_version="v2" ) {
>> environments.
>> 1. {
>> 2. "id": 86,
>> 3. "name": "test_module1",
>> 4. "created_at": "2014-03-19T12:01:34Z",
>> 5. "updated_at": "2014-03-19T12:01:34Z",
>> 6. "smart_variables":
>> 7. [
>> 8. ],
>> 9. "smart_class_parameters":
>> 10. [
>> 11. {
>> 12. "parameter": "test_version",
>> 13. "id": 266
>> 14. }
>> 15. ],
>> 16. "environments":
>> 17. [
>> 18. {
>> 19. "name": "development",
>> 20. "id": 4
>> 21. },
>> 22. {
>> 23. "name": "production",
>> 24. "id": 1
>> 25. }
>> 26. ],
>> 27. "":
>> 28. [
>> 29. ]
>> FOREMAN: 1.4.0
>> PUPPET: 3.4.2
>> Greg
>> email to foreman-dev...@googlegroups.com .
