Is it possible to use an RHN Satellite 5.x server (or Spacewalk I suppose)
as Installation Media for Foreman?
I'm not sure where the $major, $minor or $arch parts of a URL might exist,
or even if it's possible in the first place to go down this route.
Cheers
Duncan
> I can't see a reason why it cant be used.
the variables in the install media are just a way to use one url to
represent multiple repos, e.g.
Say you have expansive-os version 1.2 and expansive-os version 2.3
you could have
/repos/expensive-os-$major.$minor and that would be translated to either
one of the os (based on your selection).
You don't need to use this feature if there is no need for variable
substitutions ?
Ohad
On Wed, Oct 16, 2013 at 8:58 PM, Duncan Innes wrote:
Cheers
Duncan
"Foreman users" group.
Heya,
> suppose) as Installation Media for Foreman?
I would think so, but i have not used it myself (but i am in the process
of evaluating it).
I think you would have to 'publish' the Basechannel. By 'publish', i
mean to create a kickstartable distribution in Spacewalk/Satellite. For
more info, consult the Spacewalk/Satellite about Provisioning.
Regards,
Mattias
On 10/16/2013 07:58 PM, Duncan Innes wrote:
Mattias Giese
Linux Consultant & Trainer
Mail: giese@b1-systems.de
B1 Systems GmbH
Osterfeldstraße 7 / 85088 Vohburg / http://www.b1-systems.de
GF: Ralph Dehner / Unternehmenssitz: Vohburg / AG: Ingolstadt,HRB 3537
If you have a kickstart tree and profile in Satellite just look at the url
parameter in the raw kickstart file it generates.
Mine shows…
url --url http://satellite.domain.local/ks/dist/ks-rhel-x86_64-server-6-6.4
Haven't tried it yet but this should work as a normal repo which you can
point to during installation.
Please report back if it works or not, I'd be interested…
Cheers
Sandro
> Cheers
> Duncan
I've got this set up in my environment.
You will need to create a kickstart distribution in Satellite. I'm using
the RHEL 6 channel as my base channel.
Once that is complete, you can add an installation media in foreman, and
use a path similar to the following:
http://satellite/ks/dist/ks-rhel-$arch-server-$major-$version
Additionally, you'll probably want to look at adding spacewalk_type = site
and spacewalk_host to your global parameters. That way, in your ks
template you can use the following:
repo --name=rhel-<%= @arch -%>-server-optional-<%= @osver %>
–baseurl=http://<%= @host.params["spacewalk_host"]
-%>/ks/dist/child/rhel-<%= @arch %>-server-optional-<%= @osver
%>/ks-rhel-<%= @arch %>-server-<%= @osver %>-<%=
@host.operatingsystem.major %>.<%= @host.operatingsystem.minor %>
and later use <%= snippet 'redhat_register' %> to register to Satellite.
Hope that helps.
> Cheers
> Duncan
That was my current thinking Sandro, but I got a blank page when I tried
pointing a browser at my kickstart links. Expected to at least see some
information somehow.
Not quite in a position to test it from foreman yet, but I'm getting there.
D
> Mine shows..
> url --url
> Please report back if it works or not, I'd be interested...
> Cheers
> Sandro
Hadn't even crossed my mind to use a kickstart distribution. Thanks - will
check this out as soon as I can.
Sandro/Duncan
Have either of you had a chance to test this further?
I've setup a local dev env using VBox, with 3 nodes, 1 running
Puppet/Foreman with DNS/DHCP/TFTP, 1 running Satellite and 1 to test
PXEBooting.
I've pulled the url out of a Spacewalk generated KS file, and stuck it into
my Foreman provisioning script, and created a new host in Foreman using the
updated KS script.
Upon starting the PxeBoot node, it appears to run through fine, downloading
the initrd files, and pulling the kickstart script from Foreman.
However it appears to die out when trying to receive the repository
metadata. Error is:
Cannot retrieve repository metadata (repomd.xml) for repository:
> anaconda-OracleLinuxServer-201105261616.x86_64.
> Please verify it's path and try again.
So not sure if I've missed a step, or if it just wont work without using
Cobbler to trigger the system build…
Will try and spend a bit more time on it tomorrow to explore further
Cheers
Gavin
> D
>> url parameter in the raw kickstart file it generates.
>> Mine shows..
>> url --url
>> Cheers
>> Sandro
This might be a bit hackish… but in our environment we setup an 'install'
root outside of spacewalk to do the install and used that as the media.
Then in the provisioning script it runs the rhnreg_ks to join to spacewalk,
using an activation key that has the channels it will need.
On Monday, October 21, 2013 9:17:33 AM UTC-7, Gavin Williams wrote:
> Sandro/Duncan
> PXEBooting.
> into my Foreman provisioning script, and created a new host in Foreman
> using the updated KS script.
> downloading the initrd files, and pulling the kickstart script from
> Foreman.
> metadata. Error is:
> Cobbler to trigger the system build...
> Will try and spend a bit more time on it tomorrow to explore further :)
> Cheers
> Gavin
>> there.
>> D
>>> Mine shows..
>>> url --url
>>> Cheers
>>> Sandro
I have not had the time to test this, unfortunately.
But I'll definitely have a look at pulp, seems promising!
Cheers
On Monday, October 21, 2013 6:17:33 PM UTC+2, Gavin Williams wrote:
> Sandro/Duncan
> PXEBooting.
> Foreman.
> metadata. Error is:
> Cheers
> Gavin
>> there.
>> D
>>> Mine shows..
>>> url --url
>>> Cheers
>>> Sandro
Gavin,
No chance as yet. An unexpected change freeze came along (quite literally
out of nowhere). So whilst the Foreman system that I can play with and my
Satellite are fully available to test, I'm not allowed to create any new
virtual guests or try to provision a physical box for another fortnight.
D
On Monday, 21 October 2013 17:17:33 UTC+1, Gavin Williams wrote:
> Sandro/Duncan
> PXEBooting.
> Foreman.
> metadata. Error is:
> Cheers
> Gavin
>> there.
>> D
>>> Mine shows..
>>> url --url
>>> Cheers
>>> Sandro
Kaliel
Yeh, i've currently got a separate yum mirror which has got the install
media available.
However I'd quite like to migrate to Spacewalk, as it seems to cut down on
the space requirements by matching packages across repository's and
channels… Whereas with mrepo I'm mirroring the same data several times…
Cheers
Gav
’install’ root outside of spacewalk to do the install and used that as the
media. Then in the provisioning script it runs the rhnreg_ks to join to
spacewalk, using an activation key that has the channels it will need.
Sandro/Duncan
I’ve setup a local dev env using VBox, with 3 nodes, 1 running
PXEBooting.
I’ve pulled the url out of a Spacewalk generated KS file, and stuck it
Foreman.
metadata. Error is:
anaconda-OracleLinuxServer-**201105261616.x86_64.
Please verify it’s path and try again.
So not sure if I’ve missed a step, or if it just wont work without using
Cheers
Gavin
Not quite in a position to test it from foreman yet, but I’m getting
there.
D
Mine shows…
url --url http://satellite.domain.local/**
ks/dist/ks-rhel-x86_64-server-**6-6.4http://satellite.domain.local/ks/dist/ks-rhel-x86_64-server-6-6.4
Haven’t tried it yet but this should work as a normal repo which you
can point to during installation.
Please report back if it works or not, I’d be interested…
Cheers
Sandro
https://groups.google.com/d/topic/foreman-users/RGbXmGq7dDE/unsubscribe.
> Kaliel
> media available.
if thats your primary motivation, imho you should try pulp [1] instead.
Ohad
[1] http://pulpproject.org
On Mon, Oct 21, 2013 at 9:19 PM, fatmcgav wrote:
Cheers
Gav
Sandro/Duncan
PXEBooting.
Foreman.
metadata. Error is:
Cheers
Gavin
tried pointing a browser at my kickstart links. Expected to at least see
some information somehow.
there.
D
Mine shows…
Cheers
Sandro
Ohad
Cheers for the recommendation. I have read about Pulp before, but must admit I haven't yet tried it.
Will give it a go. Is there a webui for it?
Cheers
Gav
Bk
Cheers for confirming. So following the work on plugging katello into Foreman, we should eventually be able to manage yum repos through Foreman?
Cheers
Gav
Pulp is is CLI/API only. The katello plugin will be a front end for pulp.
– bk
On 10/21/2013 02:49 PM, Gavin Williams wrote:
> Ohad
> Cheers
> Gav
And, to be clear, once pulp gets deb support… ideally we can manage apt
repos as well.
– bk
On 10/21/2013 03:24 PM, Gavin Williams wrote:
> Bk
> Cheers
> Gav
Sounds great
Happy to help where I can
Gav
Bk
Cheers
Gav
Yes, that is the goal
– bk
To unsubscribe from this topic, visit https://groups.google.com/d/**
topic/foreman-users/**RGbXmGq7dDE/unsubscribehttps://groups.google.com/d/topic/foreman-users/RGbXmGq7dDE/unsubscribe
foreman-users+unsubscribe@googlegroups.comforeman-users%2Bunsubscribe@googlegroups.com
Visit this group at http://groups.google.com/**group/foreman-usershttp://groups.google.com/group/foreman-users
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
