I'm trying to set up a Foreman Smart Proxy for MS DNS. I can't get the
Proxy service to start it times out. I've installed this on Windows 2008
R2 with latest smart proxy download from git. Has anyone been able to set
this up so the dnscmd creates\deletes DNS records?
i have some issues sometime ago with that and i solved let me check my
notes i can pass you
On Friday, January 9, 2015 at 12:24:01 AM UTC+10, jason whalen wrote: > > I'm trying to set up a Foreman Smart Proxy for MS DNS. I can't get the > Proxy service to start it times out. I've installed this on Windows 2008 > R2 with latest smart proxy download from git. Has anyone been able to set > this up so the dnscmd creates\deletes DNS records? >How are you starting the service? Did you do that add service and run it
from services.msc? That is currently broken,
http://projects.theforeman.org/issues/8793
You can run the smart-proxy from a powershell/cmd windows.
cd P:\ath\to\smart-proxy-1.7-stable
smart-proxy-1.7-stable> ruby .\bin\smart-proxy
On Thursday, January 8, 2015 at 8:24:01 AM UTC-6, jason whalen wrote: > > I'm trying to set up a Foreman Smart Proxy for MS DNS. I can't get the > Proxy service to start it times out. I've installed this on Windows 2008 > R2 with latest smart proxy download from git. Has anyone been able to set > this up so the dnscmd creates\deletes DNS records? >> How are you starting the service? Did you do that add service and run it
> Bug #8793: Smart-proxy does not run as a service on Windows - Smart Proxy - Foreman
It looks like the refactoring in the proxy (around version 1.6) broke
windows support, in the meanwhile, you might be better of installing an
older version of the proxy instead, as I dont think that the dhcp feature
changed that much since.
Ohad
On Tue, Jan 13, 2015 at 12:52 AM, Zachary Herner wrote:On Thursday, January 8, 2015 at 8:24:01 AM UTC-6, jason whalen wrote:
I’m trying to set up a Foreman Smart Proxy for MS DNS. I can’t get the
Proxy service to start it times out. I’ve installed this on Windows 2008
this up so the dnscmd creates\deletes DNS records?–
"Foreman users" group.
