I'm trying to set up foreman with puppet. Puppet is already running for
testing purpose
Foreman is installed and configured to be an ENC but for now the reports
tab does not report anything
I have followed the wiki
http://theforeman.org/projects/foreman/wiki/Puppet_Reports
grep report /etc/puppet/puppet.conf
report=true
- On the puppetmaster/foreman (it's on the same server)
ll /usr/lib/ruby/site_ruby/1.8/puppet/reports/foreman.rb
-rw-r–r-- 1 root root 1145 21 d�c. 16:02
grep "foreman_url=" /usr/lib/ruby/site_ruby/1.8/puppet/reports/foreman.rb
$foreman_url='https://puppettest.imag.fr'
grep foreman /etc/puppet/puppet.conf
reports = log, foreman
It should be obvious, but I cannot see my mistake.
Any ideas for the next move ?
Cheers
Jean Louis Mas
> testing purpose
> http://theforeman.org/**projects/foreman/wiki/Puppet_Reports<Puppet Reports - Foreman>
> * On the puppet agent
> # grep report /etc/puppet/puppet.conf
> report=true
> * On the puppetmaster/foreman (it's on the same server)
> # ll /usr/lib/ruby/site_ruby/1.8/puppet/reports/foreman.rb
> -rw-r–r-- 1 root root 1145 21 déc. 16:02 /usr/lib/ruby/site_ruby/1.8/
> # grep "foreman_url=" /usr/lib/ruby/site_ruby/1.8/
> $foreman_url='https://**puppettest.imag.fr <https://puppettest.imag.fr>'
> # grep foreman /etc/puppet/puppet.conf
> by default, only reports with some meaningful info are shown, try clearing
the search bar and look again?
Ohad
On Thu, Jan 3, 2013 at 6:30 PM, Jean-Louis Mas wrote:
Cheers
Jean Louis Mas
"Foreman users" group.
To post to this group, send email to foreman-users@googlegroups.com**.
To unsubscribe from this group, send email to foreman-users+unsubscribe@**
googlegroups.com foreman-users%2Bunsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/**
group/foreman-users?hl=enhttp://groups.google.com/group/foreman-users?hl=en
Hi all,
I'm suffering the same fate except I've just upgraded from a Puppet 2.6
master to 2.7. Running foreman 1.0.1 from the theforeman.org's deb
packages. Reports were working correctly and now I'm not getting any
come in at all. Clients are still running puppet 2.6. Clients don't
report errors when running and there's nothing interesting in
/var/log/puppet/ or /var/log/foreman/ on the master.
Client /etc/puppet/puppet.conf has:
[agent]
report = true
Master /etc/puppet/puppet.conf has:
[master]
What changed between 2.6 and 2.7?
Thank you,
Dan
> for testing purpose
> reports tab does not report anything
> report=true
> -rw-r--r-- 1 root root 1145 21 d�c. 16:02
Some of the more recent packages use the vendor_ruby directory instead,
you might want to double check the foreman.rb is in the correct
location, e.g. /usr/lib/ruby/vendor_ruby/puppet/reports/
Check the puppetmaster's syslog and client logs for any errors too, it
tends to log when unable to run reports.
>> for testing purpose
>> report=true
> Hi all,
> [agent]
> report = true
> [master]
Dominic Cleal
Red Hat Engineering
I checked syslog and it was failing the run the foreman report:
puppet-master[9541]: Report processor failed: Could not send report to
Foreman at https://foreman/reports/create?format=yml: undefined method
`use_ssl=' for #<Net::HTTP foreman:443 open=false>
Turns out I needed to update my foreman.rb to something suitable for the
current version of ruby.
The puppet upgrade was just a coincidence as it caused me to restart
passenger.
Thank you for the help Dominic. It's all working now.
Dan
>> Hi all,
>> 2.6 master to 2.7. Running foreman 1.0.1 from the theforeman.org's
>> deb packages. Reports were working correctly and now I'm not
>> getting any come in at all. Clients are still running puppet 2.6.
>> Clients don't report errors when running and there's nothing
>> interesting in /var/log/puppet/ or /var/log/foreman/ on the
>> master.
>> Client /etc/puppet/puppet.conf has: [agent] report = true
>> Master /etc/puppet/puppet.conf has: .. [master] ... reports = log,
>> foreman
> instead, you might want to double check the foreman.rb is in the
> correct location, e.g. /usr/lib/ruby/vendor_ruby/puppet/reports/
> it tends to log when unable to run reports.
