Settings not loaded after dev env reload & request output
I was setting up a fresh development env and I ran into two problems.
First of all, I have the problem that after autoreload cleared any loaded settings. On IRC @tbrisker said
try adding Foreman.settings.load to config/application.rb:315, seems to work for me
Is anyone else tracking this? @ezr-ondrej perhaps?
Then I also see empty lines for every request:
17:05:28 rails.1   | 2021-05-07T17:05:28 [I|app|0f3ba5cb] Started GET "/notification_recipients" for 127.0.0.1 at 2021-05-07 17:05:28 +0200
17:05:28 rails.1   | 2021-05-07T17:05:28 [I|app|0f3ba5cb] Processing by NotificationRecipientsController#index as JSON
17:05:28 rails.1   | 2021-05-07T17:05:28 [D|tax|0f3ba5cb] Current location set to Default Location
17:05:28 rails.1   | 2021-05-07T17:05:28 [D|tax|0f3ba5cb] Current organization set to Default Organization
17:05:28 rails.1   | 2021-05-07T17:05:28 [D|not|0f3ba5cb] Cache Miss: notification, writing cache for notification-4
17:05:28 rails.1   | 2021-05-07T17:05:28 [D|not|0f3ba5cb] Expiring notification cache notification-4 in 3600 seconds
17:05:28 rails.1   | 2021-05-07T17:05:28 [D|app|0f3ba5cb] Body: {"notifications":[]}
17:05:28 rails.1   | 2021-05-07T17:05:28 [I|app|0f3ba5cb] Completed 200 OK in 29ms (Views: 0.1ms | ActiveRecord: 4.8ms | Allocations: 20559)
17:05:28 rails.1   |  0f3ba5cb |
17:05:38 rails.1   | 2021-05-07T17:05:38 [I|app|303b334c] Started GET "/notification_recipients" for 127.0.0.1 at 2021-05-07 17:05:38 +0200
17:05:38 rails.1   | 2021-05-07T17:05:38 [I|app|303b334c] Processing by NotificationRecipientsController#index as JSON
17:05:38 rails.1   | 2021-05-07T17:05:38 [D|tax|303b334c] Current location set to Default Location
17:05:38 rails.1   | 2021-05-07T17:05:38 [D|tax|303b334c] Current organization set to Default Organization
17:05:38 rails.1   | 2021-05-07T17:05:38 [D|not|303b334c] Cache Hit: notification, reading cache for notification-4
17:05:38 rails.1   | 2021-05-07T17:05:38 [D|app|303b334c] Body: {"notifications":[]}
17:05:38 rails.1   | 2021-05-07T17:05:38 [I|app|303b334c] Completed 200 OK in 12ms (Views: 0.1ms | ActiveRecord: 0.6ms | Allocations: 13578)
17:05:38 rails.1   |  303b334c |
Is this also a known problem? Any idea where this comes from?
I’m not using autoreload because it generally doesn’t work, but I’ll take a look into it, as it should work because of this line: foreman/foreman.rb at b6b6ffc01ca7065182571a221d4a02e1baa25127 Ā· theforeman/foreman Ā· GitHub
Though it might be a case, that it gets here before all the descendants are loaded, so there are no subclasses to load the setting definitions from.
I’ve managed to work around this issue locally by adding
to config/application.rb:318.
This is being tracked at Bug #32489: Setting registry doesn't reload properly on autoreload - Foreman.
My experience is that it usually does work, and if it doesn’t it’s something we need to fix. Restarting the server on every code change is a PITA.
I agree with @tbrisker, we should keep autoreloading to work. I believe it’s important for people who don’t know yet how to fix a $thing and need to experiment. Typically new contributors or myself :slight_smile:
I’ll also add to that that autoreload is the default dev deployment. Having a broken-by-default setup is a painful experience.
I agree and I believe it is something we should try fixing asap. I also agree that for most cases it works, but with multiple plugins there are gotchas. I myself, have fixing the dev reload properly in my todo, but it would seem that for now I’ve managed just to break it :man_facepalming:
This should fix the issue:
