all_inc_hosts = []
inc_hgroups.each do |key, value|
inc_hosts = Hostgroup.find_by_id(key.id).hosts
inc_hosts.each do |hkey, hvalue|
all_inc_hosts << hkey.name
end
end
Yeah, it's ugly and probably has a lot of flaws, but, I'm pretty damn new
to ruby
Anyway, how do I translate this to something that would actually render in
the Foreman web UI?
Yep, I'm aware of that A couple reasons this won't work for what I want:
"hostgroup = CentOS-devel" won't match any Nested group from
"CentOS-devel". I want Hosts the nested groups, too. i.e.
Hostgroup->Datacenter->VM->App_name->Dev/QA/Prod. I'd want all the Hosts
that are in App_name to show, regardless of Environment, which my query
above does.
I prefer a tab on the "Host Group edit" page, similar to "Puppet
Classes", etc. To me, it makes more sense to have that information handy
there, than have to pull up a different page (All Hosts) and search. Also,
I don't really want any action associated with the list of Hosts in this
tab, except for maybe the Hostname being a link to that Hosts page in
Foreman.
David
On Friday, June 6, 2014 12:27:39 AM UTC-7, Lukas Zapletal wrote:
> Hey,
> > I think it'd be good if Foreman had a tab on the "Host Group edit" page
> > that showed all the hosts in a given HostGroup.
> are you aware of our flexible and awesome search box? :-)
> What you can do there on the Hosts page is:
> and you will get the desired list. Then you can select them all and
> select action from the dropdown.
> Later,
> Lukas "lzap" Zapletal
> irc: lzap #theforeman
> above does.
Per discussion with Joseph, we have a pending patch that fixes this
behavior:
Just a heads up David, https://github.com/theforeman/foreman/pull/1502 is
now merged, you should be able to do your query through the search box now,
however you'd still have to bring up a new tab to do so
On Mon, Jun 9, 2014 at 10:35 AM, Lukas Zapletal wrote:
“hostgroup = CentOS-devel” won’t match any Nested group from
Hostgroup->Datacenter->VM->App_name->Dev/QA/Prod. I’d want all the Hosts
above does.
behavior:
Sorry for the late reply, work got in the way, heh! That worked perfectly,
thanks! Is there a way to include that search in a page I mentioned
earlier? Almost every single person (management down to the developers)
I've shown Foreman to during the proof-of-concept wanted to have that. I'm
looking through everything and trying to figure it out, but it'll be a long
process, since my ruby sucks
And no, doing a search isn't the same thing, heh!
Thanks!
David
> however you'd still have to bring up a new tab to do so :)
>> Hosts
>> > above does.
>> behavior:
>> Feel free to test it and report if it works for you.
>> Later,
>> "foreman-dev" group.
>> email to foreman-dev...@googlegroups.com .
> Daniel Lobato
> @elobatoss
> blog.daniellobato.me
> daniellobato.me
> GPG: http://keys.gnupg.net/pks/lookup?op=get&search=0x7A92D6DD38D6DE30
