Problem: smart proxy set up required
Expected outcome: :we would like to configure region respective smart proxy server set up
Foreman and Proxy versions: 3.3 version foreman server
**Foreman and Proxy plugin versions:3.3
we completed successfully foreman set up and we tested which is successfully provisioning the virtual server on vmware platform.
Currently we are planning to set up proxy server set up please suggest me document and suggestion from your end .
I’m not sure whether you have Katello or not. Here’s the smart proxy installation documentation for 3.3
without Katello: Installing an External Smart Proxy Server 3.3
with Katello: Installing an External Smart Proxy Server 3.3
Please keep in mind, however, that this is an unsupported version and if you’re starting from scratch you should probably use the latest supported version, 3.5, for both Foreman server and smart proxy:
https://docs.theforeman.org/3.5/Installing_Proxy/index-katello.html
https://docs.theforeman.org/3.5/Installing_Proxy/index-foreman-el.html
thank you for your information.
I will configure proxy server with the help document which you provided.
I have configured successfully foreman-server but when i was trying to configure out employer certificate to get authenticate which is getting errors.
followed below steps
openssl req -new -out
hostname
-micron.csr -newkey rsa:2048 -nodes -sha256 -keyout
hostname
-micron.key -config
hostname
-micron.cnf
openssl pkcs7 -print_certs -
in
hostname
-micron.p7b -out
hostname
-micron.cer
cp
-r
/opt/ssl-certificate/hostname-micron
.cer
/etc/pki/ca-trust/source/anchors/
cp
-r
.key
/etc/pki/tls/private
update-ca-trust
openssl x509 -noout -modulus -
in
/etc/pki/ca-trust/extracted/openssl/ca-bundle
.trust.crt| openssl md5
openssl rsa -noout -modulus -
in
/etc/pki/tls/private/hostname-micron
.key | openssl md5
openssl x509 -dates -noout -
in
.trust.crt
