Smart Proxy and ssl permissions w/ puppet 3.4.3
I think Dominic had a bug/feature<https://tickets.puppetlabs.com/browse/PUP-1120>over at puppetlabs on the group permissions of the puppet SSL dir. I
recently upgraded smart proxies and puppet, but didn't notice this bug. I
have downgraded to 3.4.2 and am still hitting the issue on the private_keys
dir. The smart-proxy service fails accessing the key, because even if I
set the keys dir to 751, puppet reverts it on the next run…
Debug: Using settings: adding file resource 'privatekeydir':
'File[/var/lib/puppet/ssl/private_keys]{:ensure=>:directory,
:group=>"root", :loglevel=>:debug, :links=>:follow, :owner=>"root",
:mode=>"750", :path=>"/var/lib/puppet/ssl/private_keys", :backup=>false}'
Debug: /File[/var/lib/puppet/ssl/private_keys]/mode: mode changed '0751' to
'0750'
Is there a known good puppet version?
Thanks.
You can reconfigure Puppet's internal file permissions. We usually
recommend you add foreman-proxy to the puppet group, leave private_keys
at 0750 but add group to read to the key inside. See this section
(scroll down a little) for a puppet.conf snippet to configure this:
http://theforeman.org/manuals/1.4/index.html#5.4.2SecuringSmartProxyRequests
If you want to force 0751, you can add mode to the privatekeydir line.
··· On 18/03/14 17:42, Sean Alderman wrote: > Hi, > I think Dominic had a bug/feature > over at puppetlabs on > the group permissions of the puppet SSL dir. I recently upgraded smart > proxies and puppet, but didn't notice this bug. I have downgraded to > 3.4.2 and am still hitting the issue on the private_keys dir. The > smart-proxy service fails accessing the key, because even if I set the > keys dir to 751, puppet reverts it on the next run... > > Debug: Using settings: adding file resource 'privatekeydir': > 'File[/var/lib/puppet/ssl/private_keys]{:ensure=>:directory, > :group=>"root", :loglevel=>:debug, :links=>:follow, :owner=>"root", > :mode=>"750", :path=>"/var/lib/puppet/ssl/private_keys", > :backup=>false}' > > Debug: /File[/var/lib/puppet/ssl/private_keys]/mode: mode changed > '0751' to '0750' > > > Is there a known good puppet version?
Dominic Cleal
Red Hat Engineering
Dominic,
Thanks for the speedy reply.
The puppet config is there and has been since I setup the smart-proxy
back in July of 2013, foreman-proxy user is a member of the puppet
group…actually I have puppet asserting it's own config file with a
template designed for group shared ssl. So at least in 3.4.2 and 3.4.3,
the private_keys dir is not being set group to puppet, as of now everything
is root:root.
Honestly, I can't recall what version of puppet I was running before
1/13/2014 when I upgraded all things Foreman from 1.2 -> 1.4, and
afterwards puppet to 3.4 as well. Last week I patched again and it seems
to have broken the permissions.
I can say that today I've added o+x to /var/lib/puppet,
/var/lib/puppet/ssl, and /var/lib/puppet/ssl/private_keys, as well as
changed their groups, but when puppet runs the directory resources get
reverted to root:root/750. The actual private key is fine.
Sean M. Alderman
Senior Engineer, UDit Systems Integration and Engineering
University of Dayton
salderman1@udayton.edu
"We are not some casual and meaningless product of evolution. Each of us
is the result of a thought of God. Each of us is willed. Each of us is
loved. Each of us is necessary."
- BXVI
https://tickets.puppetlabs.com/browse/PUP-1120 over at puppetlabs on
proxies and puppet, but didn’t notice this bug. I have downgraded to
:backup=>false}'
'0751' to '0750'
You can reconfigure Puppet’s internal file permissions. We usually
Foreman :: Manual
Dominic Cleal
Red Hat Engineering
"Foreman users" group.
That's strange behaviour, I've not seen it before. Is privatekeydir set
to "group = service" or "group = puppet"?
My only other thought is that the agent might be using a different
puppet.conf to the one you're changing, but that would be very unusual.
··· -- Dominic Cleal Red Hat Engineering
On 18/03/14 18:39, Sean Alderman wrote:
Dominic,
group…actually I have puppet asserting it’s own config file with a
everything is root:root.
Honestly, I can’t recall what version of puppet I was running before
seems to have broken the permissions.
I can say that today I’ve added o+x to /var/lib/puppet,
Sean M. Alderman
salderman1@udayton.edu mailto:salderman1@udayton.edu
/“We are not some casual and meaningless product of evolution. Each of
us is the result of a thought of God. Each of us is willed. Each of us
is loved. Each of us is necessary.”/ - BXVI
On Tue, Mar 18, 2014 at 2:04 PM, Dominic Cleal <dcleal@redhat.com > mailto:dcleal@redhat.com> wrote:
> Hi,
> <https://tickets.puppetlabs.com/browse/PUP-1120> over at puppetlabs on
smart
:owner=>"root",
>     :backup=>false}'
>     '0751' to '0750'
Dominic Cleal
Red Hat Engineering
Groups "Foreman users" group.
To unsubscribe from this group and stop receiving emails from it,
send an email to foreman-users+unsubscribe@googlegroups.com
<mailto:foreman-users%2Bunsubscribe@googlegroups.com>.
<mailto:foreman-users@googlegroups.com>.
Groups “Foreman users” group.
