Upon installation of smart proxy service smart_proxy_dynflow_core fails. Starting it manually also doesn’t work.
smart_proxy_dynflow_core is installed and started
Foreman 2.1.2
Katello 3.16
CentOS 7
Systemd start for smart_proxy_dynflow_core failed!
journalctl log for smart_proxy_dynflow_core:
-- Logs begin at Thu 2020-09-17 06:10:42 UTC, end at Thu 2020-09-17 14:05:01 UTC. --
Sep 17 14:05:00 p5-ava-fmpxy-1 systemd[1]: Starting Foreman smart proxy dynflow core service...
Sep 17 14:05:01 p5-ava-fmpxy-1 systemd[1]: Failed to start Foreman smart proxy dynflow core service.
Sep 17 14:05:01 p5-ava-fmpxy-1 systemd[1]: Unit smart_proxy_dynflow_core.service entered failed state.
Sep 17 14:05:01 p5-ava-fmpxy-1 systemd[1]: smart_proxy_dynflow_core.service failed.
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/service/systemd.rb:201:in `rescue in start'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/provider/service/systemd.rb:196:in `start'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/service.rb:110:in `block (3 levels) in <module:Puppet>'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:490:in `set'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:570:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/service.rb:127:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:241:in `sync'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:136:in `sync_if_needed'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:82:in `perform_changes'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:21:in `evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:267:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:287:in `eval_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:191:in `call'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:191:in `block (2 levels) in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:546:in `block in thinmark'
/opt/puppetlabs/puppet/lib/ruby/2.5.0/benchmark.rb:308:in `realtime'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:545:in `thinmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:191:in `block in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:122:in `traverse'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:178:in `evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:240:in `block (2 levels) in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:161:in `with_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:185:in `block (2 levels) in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:184:in `block in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:233:in `block in benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:183:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:399:in `run_internal'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:227:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:62:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:314:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:210:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:341:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:253:in `block in main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:207:in `main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:177:in `run_command'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:382:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:735:in `exit_on_fail'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:382:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:143:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:77:in `execute'
/opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
