I have a relatively simple question. I am currently developing a foreman plugin as well as a smart proxy plugin. I can get my smart proxy to show up in the foreman plugin web interface, but how do I get the foreman plugin to show up in smart proxy features? When I hit refresh features, it just shows “logs” as a feature. Thanks.
stephen-nelsonjr https://community.theforeman.org/u/stephen-nelsonjr
July 16I have a relatively simple question. I am currently developing a foreman
Foreman needs to know about the feature in adavance, it usually maps to
some API calls that are unique to that feature… so
in
core, or via a foreman plugin.
How to Create a Smart-Proxy Plugin - Foreman is the page that describes how to write a plugin. I hope you at least found that
Assuming you have gotten to the Plugin Initialization then you also need to create a config file. By default all plugins are disabled. Creating a settings.d/my_plugin.yml
with the following content is probably what you’re looking for.
# Can be true, false, or http/https to enable just one of the protocols
:enabled: true
Then you should see it if you go to http://proxy.example.com:8080/features. If you’ve done all that, then you should continue with what @ohadlevy suggested.
Thanks! I got through all of it already but thank you for checking! Hopefully what @ohadlevy suggested will assist me.
