cannot get Monitoring Proxy to work after following documents, instead i get the following each time I try to provision a node with Monitoring Proxy selected
Failed to create a monitoring object allan-redshaw.xxx.net: ERF12-4778 [ProxyAPI::ProxyException]: Unable to create monitoring host object for allan-redshaw.xxx.net ([RestClient::NotFound]: 404 Not Found) for proxy https://hmjump.xxx.net:8443/monitoring and Failed to undo update compute oVirt-Compute-Resource (oVirt)
expect it to work and node having monitoring tab and also showing up in icingaweb2
1.24.2
CentOS 7.7
/var/log/icinga2/icinga2.log
[2020-03-31 22:16:38 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44374): Operation canceled
[2020-03-31 22:16:39 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44376): Operation canceled
[2020-03-31 22:16:40 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44378): Operation canceled
[2020-03-31 22:16:41 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44380): Operation canceled
[2020-03-31 22:16:42 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44382): Operation canceled
[2020-03-31 22:16:43 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44384): Operation canceled
[2020-03-31 22:16:44 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44386): Operation canceled
[2020-03-31 22:16:45 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44388): Operation canceled
[2020-03-31 22:16:46 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44390): Operation canceled
[2020-03-31 22:16:47 -0400] critical/ApiListener: Client TLS handshake failed (from [192.168.11.17]:44392): Operation cancel
/var/log/foreman-proxy/proxy.log
usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `call'
/usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2020-03-31T22:25:17 [E] Error while monitoring: Permission denied - /etc/foreman-proxy/monitoring/foreman.key
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_client.rb:99:in `read'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_client.rb:99:in `key'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_client.rb:119:in `certificate_request?'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_client.rb:54:in `events_socket'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_api_observer.rb:22:in `block in monitor'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_api_observer.rb:19:in `loop'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_api_observer.rb:19:in `monitor'
/usr/share/gems/gems/smart_proxy_monitoring-0.1.2/lib/smart_proxy_monitoring_icinga2/icinga2_api_observer.rb:58:in `block in do_start'
/usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `call'
At a lost as to what is missing. Would really like to get this working… Any assistance is appreciated
