Smart Proxy is no longer communicating: Not all necessary pulp workers running at https://smartproxy.lab.lan/pulp/api/v3
I detected an issue, which apparently happened a few weeks ago. After one of the later upgrades (I don’t recall which one was done when this error started appearing), the smart proxy doesn’t sync anymore. Neither full sync nor incremental works, also the sync after publishing a new content version.
When I click on the smart proxy in the GUI, I get this message:
Oops, we’re sorry but something went wrong Not all necessary pulp workers running at https://smartproxy.lab.lan/pulp/api/v3.
Smart Proxy to sync.
Foreman 3
Katello 4.2
CentOS 7.9
foreman-rake errors:fetch_log request_id=9c96379d
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
2021-10-21T13:56:44 [I|app|9c96379d] Started GET "/smart_proxies/2-smartproxy-lab-lan/pulp_storage" for 10.10.14.55 at 2021-10-21 13:56:44 +0200
2021-10-21T13:56:44 [I|app|9c96379d] Processing by SmartProxiesController#pulp_storage as HTML
2021-10-21T13:56:44 [I|app|9c96379d]   Parameters: {"id"=>"2-smartproxy-lab-lan"}
2021-10-21T13:56:45 [W|app|9c96379d] Not all necessary pulp workers running at https://smartproxy.lab.lan/pulp/api/v3.
2021-10-21T13:56:45 [I|app|9c96379d] Backtrace for 'Not all necessary pulp workers running at https://smartproxy.lab.lan/pulp/api/v3.' error (RuntimeError): Not all necessary pulp workers running at https://smartproxy.lab.lan/pulp/api/v3.
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/app/models/katello/ping.rb:200:in `pulp3_without_auth'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/app/models/katello/concerns/smart_proxy_extensions.rb:375:in `ping_pulp3'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/app/models/katello/concerns/smart_proxy_extensions.rb:180:in `pulp_disk_usage'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/app/controllers/katello/concerns/smart_proxies_controller_extensions.rb:29:in `pulp_storage'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/base.rb:195:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/rendering.rb:30:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:112:in `block in run_callbacks'
 9c96379d | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
 9c96379d | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
 9c96379d | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/sweeper.rb:14:in `around'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:139:in `run_callbacks'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/callbacks.rb:41:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/rescue.rb:22:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications.rb:180:in `block in instrument'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications.rb:180:in `instrument'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/base.rb:136:in `process'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/rendering.rb:39:in `process'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal.rb:190:in `dispatch'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal.rb:254:in `dispatch'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/routing/route_set.rb:33:in `serve'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/journey/router.rb:49:in `block in serve'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/journey/router.rb:32:in `each'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/journey/router.rb:32:in `serve'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/routing/route_set.rb:834:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/lib/katello/middleware/event_daemon.rb:10:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/static.rb:126:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-dsl-2.4.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/static_dispatcher.rb:66:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/extractor/recorder.rb:137:in `call'
 9c96379d | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
 9c96379d | /usr/share/foreman/lib/foreman/middleware/catch_json_parse_errors.rb:9:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/conditional_get.rb:27:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
 9c96379d | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/cookies.rb:648:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:101:in `run_callbacks'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/rack/logger.rb:37:in `call_app'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/rack/logger.rb:28:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
 9c96379d | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/request_id.rb:27:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.2.0.1/lib/katello/prevent_json_parsing.rb:12:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/executor.rb:14:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.3.0/lib/secure_headers/middleware.rb:11:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/engine.rb:527:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/railtie.rb:190:in `public_send'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/railtie.rb:190:in `method_missing'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.3.2/lib/puma/configuration.rb:249:in `call'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.3.2/lib/puma/request.rb:77:in `block in handle_request'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.3.2/lib/puma/thread_pool.rb:338:in `with_force_shutdown'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.3.2/lib/puma/request.rb:76:in `handle_request'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.3.2/lib/puma/server.rb:438:in `process_client'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.3.2/lib/puma/thread_pool.rb:145:in `block in spawn_thread'
 9c96379d | /opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2021-10-21T13:56:45 [I|app|9c96379d]   Rendering common/500.html.erb
2021-10-21T13:56:45 [I|app|9c96379d]   Rendered common/500.html.erb (Duration: 13.9ms | Allocations: 5983)
2021-10-21T13:56:45 [I|app|9c96379d] Completed 500 Internal Server Error in 677ms (Views: 15.2ms | ActiveRecord: 17.6ms | Allocations: 27071)
Foreman version: 3.0.0
Plugins:
 - foreman-tasks 5.1.0
 - foreman_ansible 6.4.1
 - foreman_puppet 1.0.3
 - foreman_remote_execution 4.7.0
 - katello 4.2.0.1
