It works fine with OpenSCAP 1.2.9 (Debian Stretch) and 1.2.10 (EL7),
but will terribly fail on EL6 (1.2.13) and Fedora 25 (1.2.14).
Pulling builds from Koji I tracked that down to 1.2.11 being the
culprit, a proper bisect between 1.2.10 and 1.2.11 is yet outstanding.
And I guess an OpenSCAP update in EL7 is coming at some point too.
I am yet unsure if that is us doing something fishy, or whether it is
an actual bug in OpenSCAP.
Cheers
Evgeni
Beste Grüße/Kind regards,
Evgeni Golov
Software Engineer
Red Hat GmbH, http://www.de.redhat.com/, Registered seat: Grasbrunn,
Commercial register: Amtsgericht Muenchen, HRB 153243,
Managing Directors: Charles Cachera, Michael Cunningham, Michael
O’Neill, Eric Shander
Running this with OpenSCAP 1.2.10 results in the following warning printed:
WARNING: Processing an unresolved XCCDF document. This may have
unexpected results.
You can resolve the document using "oscap xccdf resolve -o
resolved-xccdf.xml xccdf.xml"
This warning is missing when executing the above with 1.2.11, instead
you get the already known:
Internal error: Could not acquire handle to xccdf.xml source.
[ds_sds_session.c:339] (OpenSCAP::OpenSCAPError)
I am calling it a day, and will dig deeper tomorrow.
On Wed, May 17, 2017 at 4:41 PM, Evgeni Golov wrote:
> Ohai,
> the tests for smart_proxy currently fail when executed with OpenSCAP
>>= 1.2.11 (like in EL6 or Fedora 25):
> Error: test_scap_content_guide(ScapContentParserApiTest):
> JSON::ParserError: 784: unexpected token at 'Error occurred:
> [ds_sds_session.c:357]
> /home/remote/egolov/.gem/ruby/gems/json-1.8.6/lib/json/common.rb:155:in `parse'
> /tmp/smart_proxy_openscap/test/scap_content_parser_api_test.rb:50:in
> `test_scap_content_guide'
> 47:
> 48: def test_scap_content_guide
> 49: post
> '/scap_content/guide/xccdf_org.ssgproject.content_profile_rht-ccp',
> @scap_content, 'CONTENT_TYPE' => 'text/xml'
> => 50: result = JSON.parse(last_response.body)
> 51: assert(result['html'].start_with?(''))
> 52: assert(last_response.successful?)
> 53: end
> Seems that Marek did hit that issue at some point too:
> http://projects.theforeman.org/issues/17839
> Cheers
> Evgeni
> Evgeni Golov
> Software Engineer
> ________________________________________________________________________
> O'Neill, Eric Shander
Evgeni Golov
Software Engineer
I looked into upstream tests
(https://github.com/OpenSCAP/ruby-openscap/blob/master/test/ds/sds_test.rb#L43-L54)
and they are supposed to catch that, but they do not, as their loop
never executes with their DS file.
Using our file I get the exact same error as in my fist mail. And
using our file I don't get the warning with my code above either.
So it's seems that the issue is in OpenSCAP itself.
I'll bring that up on their issue tracker tomorrow, let's see what they think.
Thanks for listening.
Evgeni
On Wed, May 17, 2017 at 5:53 PM, Evgeni Golov wrote:
> Trivial reproducer, without our code:
> require 'openscap'
> require 'openscap/source'
> require 'openscap/ds/arf'
> require 'openscap/xccdf/benchmark'
> scap_file= '/tmp/ruby-openscap/test/data/sds-complex.xml'
> OpenSCAP.oscap_init
> @source = OpenSCAP::Source.new(scap_file)
> sds = OpenSCAP::DS::Sds.new @source
> sds.select_checklist
> html = sds.html_guide
> (the file is https://github.com/OpenSCAP/ruby-openscap/blob/master/test/data/sds-complex.xml)
> unexpected results.
>> Ohai,
>> 47:
>> 49: post
>> 53: end
>> Cheers
>> Evgeni
>> Evgeni Golov
>> Software Engineer
> Evgeni Golov
> Software Engineer
Evgeni Golov
Software Engineer
This has been identified as an upstream regression:
And a patch has been already merged:
Should ship in OpenSCAP 1.2.15
On Thu, May 18, 2017 at 6:15 PM, Evgeni Golov wrote:
> So, continuing talking to myself ;)
> Evgeni
>> require 'openscap'
>> OpenSCAP.oscap_init
>> unexpected results.
>>> Ohai,
>>> 47:
>>> 49: post
>>> 53: end
>>> Cheers
>>> Evgeni
>>> Evgeni Golov
>>> Software Engineer
>> Evgeni Golov
>> Software Engineer
> Evgeni Golov
> Software Engineer
Evgeni Golov
Software Engineer
