Hi Folks,
I am attempting to run the smart-proxy tests and am getting some errors.
I suspect a mismatched gem somewhere. Could someone confirm that this
selection of gems is correct for running under ruby-2.0.0-p353?
Alternatively could I get a copy of this information from the Jenkins CI
environment?
pkelly@vihla676(theforeman-develop): bundle list
Gems included by the bundle:
- addressable (2.3.8)
- ast (2.2.0)
- builder (3.2.2)
- bundler (1.9.6)
- ci_reporter (1.9.3)
- coderay (1.1.1)
- crack (0.4.3)
- facter (2.4.6)
- ffi (1.9.10)
- gssapi (1.2.0)
- hashdiff (0.3.0)
- hiera (1.3.4)
- json (1.8.3)
- json_pure (1.8.3)
- metaclass (0.0.4)
- method_source (0.8.2)
- mocha (0.13.3)
- parser (2.3.1.2)
- powerpack (0.1.1)
- pry (0.10.3)
- puppet (3.7.5)
- rack (1.5.5)
- rack-protection (1.5.3)
- rack-test (0.6.3)
- rainbow (2.1.0)
- rake (10.4.2)
- rake-compiler (0.9.9)
- rdoc (4.2.0)
- rkerberos (0.1.3)
- rubocop (0.38.0)
- rubocop-checkstyle_formatter (0.2.0)
- ruby-augeas (0.5.0)
- ruby-libvirt (0.6.0)
- ruby-progressbar (1.8.1)
- rubyipmi (0.10.0)
- safe_yaml (1.0.4)
- sinatra (1.4.7)
- single_test (0.6.0)
- slop (3.6.0)
- smart_proxy (1.13.0.develop)
- test-unit (2.0.0.0)
- tilt (1.4.1)
- unicode-display_width (1.0.5)
- webmock (2.1.0)
Thanks In Advance ,
Paul
> Hi Folks,
Hi!
> environment?
You can see what gems are installed here:
http://ci.theforeman.org/job/test_proxy_develop_pr_core/804/puppet=4.3.0,ruby=2.0.0/consoleFull
Anyway, what errors are you seeing when you run tests? Have you tried
'bundle exec rake test' (that uses gems in the smart-proxy bundle)?
On 06/07, paul kelly wrote:
Daniel Lobato Garcia
@dLobatog
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
http://ci.theforeman.org/job/test_proxy_develop/ is the test job, linked
from the README if you need it in future.
http://ci.theforeman.org/job/test_proxy_develop/puppet=3.8.0,ruby=2.0.0/lastSuccessfulBuild/console
is the last run for Ruby 2.0.0, scroll most of the way down past the RVM
setup to find the gem list.
On 07/06/16 14:11, paul kelly wrote:
> Hi Folks,
> errors. I suspect a mismatched gem somewhere. Could someone confirm that
> this selection of gems is correct for running under ruby-2.0.0-p353?
> environment?
Dominic Cleal
dominic@cleal.org
Thanks Daniel but everything is now working fine. You just have to use the
right gems. . . . .
Hi Folks,
Hi!
errors.
environment?
’bundle exec rake test’ (that uses gems in the smart-proxy bundle)?
@dLobatog
daniellobato.me
"foreman-dev" group.
