I had them at debug. If the leve is not enough ro they are the wrong logs let me know. Pretty sure this is the right stuff. I’ve replaced our company name with ‘company’.
@mmoll dhcp_browser seems to be reading the leases file, but not displaying them in the UI. I can’t spot anything obvious in the logs, just wondered if you had any ideas.
I see. I just checked dhcp_browser 0.0.8 works with current DEB nightlies and it does. To be able to say anything I’d need to set up everything with RPMs and these versions, which is a bit much. I’m a bit unsure if 0.0.8 would work with Foreman 1.16. According to the logs at least dhcp_browser does connect to the proxy to fetch the leases…
