Hi List !
I am trying to create a custom Smart Variable that will provide a Default
value, but I would like to override it with another value IF the host
belongs to a specific subnet. So I need to find the right matcher for
subnet. Eg should a host has the ip address 10.48.54.14/22
NETMASK=255.255.252.0
BROADCAST=10.48.55.255
NETWORK=10.48.52.0 —> this is the matcher looking for.
I have tried subnet=10.48.52.0 but it doesn't pickup between the objects in
the Order list, even though I added it there.
subnet
fqdn
hostgroup
os
domain
Are you aware of the name that needs to be there ? Perhaps
subnet is a non existent Variable. Mr foreman version in 1.7
Best regards,
Nikos
The matcher currently uses the subnet name, network address and CIDR
prefix as defined in Foreman. So if your subnet name was "Production",
use a matcher of:
subnet=Production (10.48.52.0/22)
This will be changed in 1.13.0 to use the subnet name only.
Ensure the host's network interfaces have the subnet set, they won't
have it set automatically during fact imports.
On 04/07/16 12:54, Nikos Zaharioudakis wrote:
> Hi List !
> Default value, but I would like to override it with another value IF the
> host belongs to a specific subnet. So I need to find the right matcher
> for subnet. Eg should a host has the ip address 10.48.54.14/22
> NETWORK=10.48.52.0 ---> this is the matcher looking for.
Dominic Cleal
dominic@cleal.org
I don't think subnet will work, but i'm not really sure. Maybe someone else
can advise
You might be better off use has_ip_network in Puppet stdlibs [1] ?
Obviously you'll need to edit the Puppet class every time you want to
change the logic though.
[1] https://forge.puppet.com/puppetlabs/stdlib/readme#has_ip_network
Sean
On Mon, Jul 4, 2016 at 12:54 PM, Nikos Zaharioudakis wrote:
Hi List !
I have tried subnet=10.48.52.0 but it doesn’t pickup between the objects
in the Order list, even though I added it there.
subnet
fqdn
hostgroup
os
domain
Best regards,
Nikos
"Foreman users" group.
> > Hi List !
> > <http://10.48.54.14/22>
> use a matcher of:
> Dominic Cleal
> dominic@cleal.org
Dear Dominic,
You nailed it. The thing is that we could clarify it a bit more in the docs
(or at least I didn't get it).In addition, in the bug
Bug #5785: Override class parameter by subnet no longer works since 1.5 - Foreman the formatting of the page,
doesn't help to get it at once
Thanks a lot for your prompt reply.
Nikos
