First time setting up Foremen and Katello. I setup a SmartProxy with the below command:
foreman-installer
--scenario foreman-proxy-content
--certs-tar-file "/root/proxy.example.org-certs.tar"
--foreman-proxy-content-parent-fqdn "foreman.example.org"
--foreman-proxy-register-in-foreman "true"
--foreman-proxy-foreman-base-url "https://foreman.example.org"
--foreman-proxy-trusted-hosts "foreman.example.org"
--foreman-proxy-trusted-hosts "proxy.example.org"
--foreman-proxy-oauth-consumer-key "blah"
--foreman-proxy-oauth-consumer-secret "blah"
--puppet-server-foreman-url "https://foreman.example.org"
The setup finishes successfully and the host appears in the “All Hosts” section in Foreman, but not under “Smart Proxies”. If I try to add a SmartProxy, it says it already exists.
I would expect the system to now appear under “Smart Proxies”.
Foreman and Proxy versions: 1.22.2
Foreman and Proxy plugin versions: Katello 3.15
Distribution and version: CentOS 7
