Greetings,
Has anyone noticed how Foreman handles Solaris Operating Systems with
Puppet 3?
I have a Solaris 10u10 box that's runninng Puppet 3.2 (opencsw
experimental) and another Solaris 10u10 running Puppet 2.7 (opencsw
standard). The facts presented between the two are different.
The 3.2 agent reports:
operatingsystem => Solaris
operatingsystemrelease => 10_u10
osfamily => Solaris
puppetversion => 3.2.2
The 2.7 agent reports:
operatingsystemrelease => 5.10
osfamily => Solaris
puppetversion => 2.7.14
Foreman is showing this guy as a "new" Solaris operating system with major
version 1010. I'm going to guess that Foreman is hoping to parse
operatingsystemrelease fact as $major.$minor and puppet/facter is no longer
conforming to that pattern?
Should I file a bug?.. with Foreman or Puppet/Facter?
Sean M. Alderman
Senior Engineer, UDit Systems Integration and Engineering
University of Dayton
300 College Park
Dayton, Ohio 45469-1530
(937) 229-5088
salderman1@udayton.edu
> Greetings,
> Puppet 3?
> osfamily => Solaris
> osfamily => Solaris
I've no idea why it changed, probably worth asking on both, we can surely
fix it at foreman side as well.
Ohad
On Thu, Aug 1, 2013 at 10:52 PM, Sean Alderman wrote:
Sean M. Alderman
300 College Park
(937) 229-5088
"Foreman users" group.
>> Greetings,
>> Puppet 3?
>> osfamily => Solaris
>> osfamily => Solaris
Well drawing on my memories from being a Solaris admin back in the
day, it looks like they made the OS version string in facter more
"precise". Basically every release of "Solaris 10" is SunOS 5.10.
10_u10, means Solaris 10 update 10. I haven't played with Solaris in
ages, and certainly not with Puppet. I'd ask on puppet-users and find
out the reason for this change. If there reasoning is well thought
out, and they are going to keep it this way, I'd file a feature
request on the Foreman side. I'm guessing they had a customer that
needed to differentiate between Solaris 10 releases, which is probably
why they made the change. (Almost tempted to boot up an S10 VM and
test, but I don't have any handy media.)
A couple other options:
- If you want the old behavior you COULD write a custom fact called
"sunosrelease" that emulates the old behavior. (IE: If you want all
S10 hosts regardless of update to return 5.10). It would be a fairly
easy task.
- If you want the new behaviour on the old version of facter, you
could patch facter to emulate the new bahavior.
Cheers,
Brian
On Thu, Aug 1, 2013 at 3:58 PM, Ohad Levy wrote:
> On Thu, Aug 1, 2013 at 10:52 PM, Sean Alderman > wrote:
I’ve no idea why it changed, probably worth asking on both, we can surely
Ohad
Sean M. Alderman
300 College Park
(937) 229-5088
That was my "baby" and was rolled into facter 1.7.0 (
https://projects.puppetlabs.com/issues/11082#note-15)
You can address it on older versions of facter as a custom fact (I do this)
John
On 2 August 2013 05:58, Ohad Levy wrote:
On Thu, Aug 1, 2013 at 10:52 PM, Sean Alderman salderman1@udayton.eduwrote:
Greetings,
Puppet 3?
I have a Solaris 10u10 box that’s runninng Puppet 3.2 (opencsw
osfamily => Solaris
osfamily => Solaris
Ohad
Ok, so where does this leave us? Foreman Bug?
Foreman is creating a new Operating System for each v10 Release if the
node's puppet agent version >= 2.7. I'm not sure if this has an impact on
unattended installs or not, but it would seem to if the user creating a
node picks the "new" Solaris OS.
Downgrading puppet seems to be the best option to keep things operating
cleanly in Foreman…and perhaps any puppet modules that are backward
compatible to 2.7 and use release fact.
I've attached a couple of Foreman Screen clips. The (hw0113) OS is the one
I manually created for unattended installs, its also the one that Foreman
assigns to the 2.7 agents. I get the reasoning for the fact change, since
none of the Solaris boxes I've migrated to Foreman's PuppetMaster are
actually running 01/13, they're all on 08/11. The only nodes I have
running 01/13 are ones done unattended provisioning with.
Perhaps we can just get Foreman to properly match the $major_u$minor and
display it correctly for puppet 3.x clients? Do I need to file a bug for
this or a feature request?
Sean M. Alderman
300 College Park
(937) 229-5088
On Thu, Aug 1, 2013 at 7:07 PM, John Warburton jwarburton@gmail.com wrote:
Greetings,
Puppet 3?
osfamily => Solaris
osfamily => Solaris
Ohad
That was my “baby” and was rolled into facter 1.7.0 (
John
“Foreman users” group.
