the rake apipie:cache:index command which we do both in build phase
and after RPM package installation is slow as hell. What is the reason
for that? Can't we redesign this to completely avoid need of
generating this kind of index? For example the page could be
JavaScript based, plugins would simply drop some metadata files and JS
would parse them hiding/showing appropriate sections on the index
page. This should not be too hard, but it will increase user
experience with installing and updating which we need to improve for
sure.
Isn't the cache also used by apipie client bindings (which are used by
tools like hammer)?
> sure.
Perhaps, but AFAIK we generate index page in all supported i18ned
languages, so the process is somehow repeated 12 times which makes is
slow I believe.
LZ
>> sure.
> tools like hammer)?
> You received this message because you are subscribed to the Google Groups "foreman-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
It's used for generating both html doc pages and json (consumed by
apipie bindings). We can't get rid of iterating over languages, but
generating docs only in json format and having html page that loads it
async and generates the content dynamically would probably bring the
desired speedup. I like it.
T.
> slow I believe.
> LZ
>>> sure.
>> tools like hammer)?
> Later,
> Lukas @lzap Zapletal
for my own setup, I've always used:
FOREMAN_APIPIE_LANGS=en rake apipie:cache:index
maybe we should consider creating a per language meta package (to include
the translations + api cache)?
Ohad
On Mon, Mar 6, 2017 at 10:34 AM, Tomas Strachota wrote:
T.
slow I believe.
for that? Can’t we redesign this to completely avoid need of
sure.
Isn’t the cache also used by apipie client bindings (which are used by
tools like hammer)?
Groups “foreman-dev” group.
Since the puppet-foreman (and thus foreman-installer) also generates the
index, it would make it difficult. IIRC the cache is regenated there
because plugins might hook into it so that's something to consider.
I do like the idea of just generating the JSON and having static HTML +
JS pages that consume the JSON.
On Mon, Mar 06, 2017 at 10:46:18AM +0200, Ohad Levy wrote:
> On Mon, Mar 6, 2017 at 10:34 AM, Tomas Strachota > wrote:
Ohad
T.
slow I believe.
sure.
tools like hammer)?
The current state is that the apipie cache consists of root index page and
page per API resource and method and JSON desription of whole API
(multiplied by number of languages). Currently we build all the resource
specific pages during the package build time. The index and JSON need to
contain all the resources according to current configuration including all
the plugins that extends API. That is the reason we have to build this
during installation.
During my benchmarks the bottleneck was loading the whole rails env. Before
the rake started to generate anything it took almost a minute on average
machine. May be different now though.
Where we can surely spare some time is rpm package installation. Every
plugin extending API calls apipie:rake:index in %postrans resulting in
about 3 consequent redundant calls for default Katello install. If we can
add some state info that index was already built in this RPM transaction we
could spare a few mins.
I'm not sure if JS would help us with creation of the JSON which is the
most used part of the API docs (used for Hammer and bindings), but I can
imagine it could be put together dynamically on first request from pieces
generated during a build time and cached. This way we could avoid index
creation completely.
Guys if there's any doable way of getting rid of index generation or
making it significantly faster, that would be super useful.
LZ
> plugin extending API calls apipie:rake:index in %postrans resulting in about
> 3 consequent redundant calls for default Katello install. If we can add some
> state info that index was already built in this RPM transaction we could
> spare a few mins.
> I'm not sure if JS would help us with creation of the JSON which is the most
> used part of the API docs (used for Hammer and bindings), but I can imagine
> it could be put together dynamically on first request from pieces generated
> during a build time and cached. This way we could avoid index creation
> completely.
> Martin
> spare a few mins.
The state check could be useful.
> completely.
Do you have any benchmark how long it takes to generate json only vs
json + html?
Since some plugins currently modify foreman api endpoints and can
potentially change (or remove) the api params too I don't think
there's easy way of generating docs json for each plugin and merging
it later.
Can we delegate this to an active job post startup? This will align with
other efforts currently?
Ohad
Martin
On Mar 6, 2017 11:11 AM, "Martin Bačovský" wrote:
