SSL Problems with new foreman installer
Hi
we are trying to install foreman from scratch latest verison on alma linux 8.6
foreman-installer -l
2022-05-30 11:30:56 [NOTICE] [root] Loading installer configuration. This will take some time.
2022-05-30 11:30:59 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2022-05-30 11:30:59 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2022-05-30 11:31:01 [NOTICE] [configure] Starting system configuration.
2022-05-30 11:31:09 [NOTICE] [configure] 250 configuration steps out of 1358 steps complete.
2022-05-30 11:31:10 [NOTICE] [configure] 500 configuration steps out of 1360 steps complete.
2022-05-30 11:31:12 [NOTICE] [configure] 750 configuration steps out of 1366 steps complete.
2022-05-30 11:31:24 [NOTICE] [configure] 1000 configuration steps out of 1367 steps complete.
2022-05-30 11:32:14 [ERROR ] [configure] /Stage[main]/Foreman::Register/Foreman_host[xxxx]: Could not evaluate: Exception SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain) in get request to: xxx
2022-05-30 11:32:14 [ERROR ] [configure] Wrapped exception:
2022-05-30 11:32:14 [ERROR ] [configure] SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain)
2022-05-30 11:32:14 [NOTICE] [configure] 1250 configuration steps out of 1367 steps complete.
2022-05-30 11:32:16 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_host[xxx]: Could not evaluate: Exception SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain) in get request to: xxx
2022-05-30 11:32:16 [ERROR ] [configure] Wrapped exception:
2022-05-30 11:32:16 [ERROR ] [configure] SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain)
2022-05-30 11:32:16 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[xxx]: Could not evaluate: Exception SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain) in get request to: xxx
2022-05-30 11:32:16 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[xxx]: Failed to call refresh: Exception SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain) in get request to: xxx
2022-05-30 11:32:16 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[xxx]: Exception SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain) in get request to: xxx
2022-05-30 11:32:18 [NOTICE] [configure] System configuration has finished.
(Dns names removed)
Whats the best appraoch to this issue? can we tell the installer to ignore the self signed and replace it later on ?
Follow the docs: Installing Foreman 3.2 server on Enterprise Linux
