T-shirt design
> ok… I have seen two items… anyone care to vote:
Going to make it more complicated :slight_smile:
> (a) Logo with "Trust Me, I run Foreman"
I like this design better for the front.
> (b) Logo with installer
But this one for the back.
··· On Fri, May 22, 2015 at 07:45:20AM -0400, Bryan Kearney wrote:
– bk
On 05/22/2015 04:11 AM, Dominic Cleal wrote:
On 22/05/15 09:10, Daniel Lobato Garcia wrote:
On 05/21, Bryan Kearney wrote:
I engaged professional help. What do folks think of this version.
Personally I think I’d wear it more without a cheeky tagline (I only
wear the current one for sports).
How about this one (could be a hammer-cli command too):
http://www.customink.com/designs/proofs/wkk0-00a4-d3cw/front-big.jpg
twitch
invalid syntax!
You received this message because you are subscribed to the Google Groups “foreman-dev” group.
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
> Personally I think I'd wear it more without a cheeky tagline (I only
> http://www.customink.com/designs/proofs/wkk0-00a4-d3cw/back-big.jpg
> http://www.customink.com/designs/foreman/wkk0-00a4-d3cw/hotlink?pc=HL-142344&cm_mmc=hotlink-_-5-_-Body_txt-_-viewbutton
I personally like this design a lot. White print as well as the yellow
helmet look great on the blue T-shirt. +1 For the vertically aligned
symbols without text on back too.
I'd maybe change the installer line for something else but I haven't got
any better idea yet.
T.
··· On 05/22/2015 10:10 AM, Daniel Lobato Garcia wrote: > On 05/21, Bryan Kearney wrote:
Note… still with silly bright colors to annoy Greg.
– bk
On 05/20/2015 03:23 AM, Daniel Lobato Garcia wrote:
On 05/19, Eric D Helms wrote:
My request would be for the front of the shirt to not make it seem I am/was
a literal construction foreman. I can’t tell you how many times I have got
that comment or question :slight_smile:
Same here. I think putting the logo in the center of the shirt instead
of where it is now would help, it looks a bit like a tag now.
Eric
On Tue, May 19, 2015 at 9:26 AM, Bryan Kearney bryan.kearney@gmail.com >>>> wrote:
My first, bad, attempt :slight_smile:
On 05/19/2015 03:51 AM, Ivan Necas wrote:
http://www.tshirt-express.it/altro-generevarie/123-trust-me-i-m-an-engineer.html
with “trust me, I’m a Foreman developer” :slight_smile:
– Ivan
----- Original Message -----
We are planning for a new set of t-shirts… does anyone has an idea for a
new design or should we just print the same like last round [1]?
Ohad
[1] Imgur: The magic of the Internet
@eLobatoss
blog.daniellobato.me
daniellobato.me
Keybase: elobato (Daniel Lobato Garcia) | Keybase
@eLobatoss
daniellobato.me
My 2 cents
+1 for more complicated variant, so variant a) with back from
Blue looks good, red is also ok.
··· -- Marek
(a) Logo with “Trust Me, I run Foreman”
– bk
twitch
invalid syntax!
Marek
+1
Will the small print even stay readable very long? I think most
screenprinting starts to fade pretty quickly, doesn't it?
  • Stephen
··· On Fri, May 22, 2015 at 02:25:20PM +0100, Greg Sutcliffe wrote: > On 22 May 2015 at 09:10, Daniel Lobato Garcia wrote: > > On 05/21, Bryan Kearney wrote: > >> I engaged professional help. What do folks think of this version. > > Personally I think I'd wear it more without a cheeky tagline (I only > > wear the current one for sports). > > > > How about this one (could be a hammer-cli command too): > > > > http://www.customink.com/designs/proofs/wkk0-00a4-d3cw/front-big.jpg > > We spend a lot of time time telling people our installer is easy to > use. This isn't going to help spread that message :)
When someone says "Trust Me". The immediate question is why. Better not
to raise the question.
The version with the install line is a better idea, but dropping all the
options to leave just "# foreman-installer" would simplify the design,
still leave it geek enough, yet avoid making the installer look
over-complex. It also has a double meaning that the wearer is an installer
of foreman, and is also the one-hit command line that is all you need to
get foreman going.
··· On Monday, 25 May 2015 09:16:04 UTC+1, Tomas Strachota wrote: > > On 05/22/2015 10:10 AM, Daniel Lobato Garcia wrote: > > On 05/21, Bryan Kearney wrote: > >> I engaged professional help. What do folks think of this version. > > Personally I think I'd wear it more without a cheeky tagline (I only > > wear the current one for sports). > > > > How about this one (could be a hammer-cli command too): > > > > http://www.customink.com/designs/proofs/wkk0-00a4-d3cw/front-big.jpg > > http://www.customink.com/designs/proofs/wkk0-00a4-d3cw/back-big.jpg > > > http://www.customink.com/designs/foreman/wkk0-00a4-d3cw/hotlink?pc=HL-142344&cm_mmc=hotlink-_-5-_-Body_txt-_-viewbutton > > > > I personally like this design a lot. White print as well as the yellow > helmet look great on the blue T-shirt. +1 For the vertically aligned > symbols without text on back too. > > I'd maybe change the installer line for something else but I haven't got > any better idea yet. > > T. > >
Forgot to say; white text on blue looks very good too.
··· On Monday, 25 May 2015 09:36:41 UTC+1, Duncan Innes wrote: > > > When someone says "Trust Me". The immediate question is why. Better not > to raise the question. > > The version with the install line is a better idea, but dropping all the > options to leave just "# foreman-installer" would simplify the design, > still leave it geek enough, yet avoid making the installer look > over-complex. It also has a double meaning that the wearer is an installer > of foreman, and is also the one-hit command line that is all you need to > get foreman going. >
<blockquote>
> http://www.customink.com/designs/foreman/wkk0-00a4-d3cw/hotlink?pc=HL-142344&amp;cm_mmc=hotlink-_-5-_-Body_txt-_-viewbutton
T.
When someone says "Trust Me". The immediate question is why. Better not to raise the question.
The version with the install line is a better idea, but dropping all the options to leave just "# foreman-installer" would simplify the design, still leave it geek enough, yet avoid making the installer look over-complex. It also has a double meaning that the wearer is an installer of foreman, and is also the one-hit command line that is all you need to get foreman going.
</blockquote>
+1 on foreman-installer, love it.
– Ivan
<blockquote>
··· ----- Original Message ----- On Monday, 25 May 2015 09:16:04 UTC+1, Tomas Strachota wrote: On 05/22/2015 10:10 AM, Daniel Lobato Garcia wrote: > On 05/21, Bryan Kearney wrote:
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com .
For more options, visit https://groups.google.com/d/optout .
> From: "Ivan Necas" <inecas@redhat.com>
> To: foreman-dev@googlegroups.com
> Sent: Monday, May 25, 2015 11:25:15 AM
> Subject: Re: [foreman-dev] t-shirt design
> > > T.
> > raise the question.
> > still
> > is
> – Ivan
Ah, that's awesome! Me too.
··· ----- Original Message ----- > ----- Original Message ----- > > On Monday, 25 May 2015 09:16:04 UTC+1, Tomas Strachota wrote: > > > On 05/22/2015 10:10 AM, Daniel Lobato Garcia wrote: > > > > On 05/21, Bryan Kearney wrote:
> > http://www.customink.com/designs/foreman/wkk0-00a4-d3cw/hotlink?pc=HL-142344&cm_mmc=hotlink--5--Body_txt-_-viewbutton
> > T.
> get foreman going.
Lol, I totally didn't make that double entendre on purpose. I like the
idea of the shorter # foreman-installer -i or whatever it is, if the
current thing is too long. Any hammer commands that would look
cool & still easy to understand?
··· On 05/25, Duncan Innes wrote: > On Monday, 25 May 2015 09:16:04 UTC+1, Tomas Strachota wrote: > > On 05/22/2015 10:10 AM, Daniel Lobato Garcia wrote: > > > On 05/21, Bryan Kearney wrote: > > -- > You received this message because you are subscribed to the Google Groups "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
@eLobatoss
daniellobato.me
Keybase: https://keybase.io/elobato
You, sir, win one internets :slight_smile:
··· On 25 May 2015 at 09:36, Duncan Innes wrote: > > > On Monday, 25 May 2015 09:16:04 UTC+1, Tomas Strachota wrote: > > When someone says "Trust Me". The immediate question is why. Better not to > raise the question. > > The version with the install line is a better idea, but dropping all the > options to leave just "# foreman-installer" would simplify the design, still > leave it geek enough, yet avoid making the installer look over-complex. It > also has a double meaning that the wearer is an installer of foreman, and is > also the one-hit command line that is all you need to get foreman going.
http://www.customink.com/designs/katello/bvn0-00a4-ddwx/hotlink?pc=HL-142344&cm_mmc=hotlink--5--Header_txt-_-prehead1
Maybe two choices?
··· ----- Original Message ----- > On Fri, May 22, 2015 at 02:25:20PM +0100, Greg Sutcliffe wrote: > > On 22 May 2015 at 09:10, Daniel Lobato Garcia wrote: > > > On 05/21, Bryan Kearney wrote: > > >> I engaged professional help. What do folks think of this version. > > > Personally I think I'd wear it more without a cheeky tagline (I only > > > wear the current one for sports). > > > > > > How about this one (could be a hammer-cli command too): > > > > > > http://www.customink.com/designs/proofs/wkk0-00a4-d3cw/front-big.jpg > > > > We spend a lot of time time telling people our installer is easy to > > use. This isn't going to help spread that message :) > > +1 > > Will the small print even stay readable very long? I think most > screenprinting starts to fade pretty quickly, doesn't it? > > > - Stephen > > -- > You received this message because you are subscribed to the Google Groups > "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to foreman-dev+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout. >
