Hi all,
I have a problem for several days, I added my vcenter in foreman, the test
connection is ok but when I want to list my vms I have this error: "There
was an error listing VMs: Undefined namespace prefix: // Soapenv: Body /*"
version foreman : 1.14.1
Saisissez le code ici…2017-03-29 10:16:51 ee3cb3aa [app] [W] Error has
occurred while listing VMs on MYVCENTER (VMware)
> Nokogiri::XML::XPath::SyntaxError: Undefined namespace prefix:
//soapenv:Body/*
/opt/rh/sclo-ror42/root/usr/share/gems/gems/nokogiri-1.6.7.rc3/lib/nokogiri/xml/searchable.rb:165:in
evaluate' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/nokogiri-1.6.7.rc3/lib/nokogiri/xml/searchable.rb:165:in
block in xpath'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/nokogiri-1.6.7.rc3/lib/nokogiri/xml/searchable.rb:156:in
map' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/nokogiri-1.6.7.rc3/lib/nokogiri/xml/searchable.rb:156:in
xpath'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.9.4/lib/rbvmomi/trivial_soap.rb:112:in
request' > /opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.9.4/lib/rbvmomi/connection.rb:87:in
call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.9.4/lib/rbvmomi/basic_types.rb:211:in
_call' > /opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.9.4/lib/rbvmomi/basic_types.rb:74:in
block (2 levels) in init'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.9.4/lib/rbvmomi/basic_types.rb:189:in
_get_property' > /opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.9.4/lib/rbvmomi/basic_types.rb:35:in
/usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:26:in
block in allvmsbyfolder' > /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:22:in
each'
allvmsbyfolder' > /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:24:in
each' > /usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:22:in
allvmsbyfolder'
/usr/share/foreman/app/services/fog_extensions/vsphere/mini_servers.rb:12:in
all' > /usr/share/foreman/app/controllers/compute_resources_vms_controller.rb:133:in
load_vms'
/usr/share/foreman/app/controllers/compute_resources_vms_controller.rb:4:in
index' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/implicit_render.rb:4:in
send_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:198:in
process_action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rendering.rb:10:in
process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:20:in
block in process_action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:117:in
call'
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:555:in
block (2 levels) in compile'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in
block (2 levels) in around' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in
call'
block (2 levels) in halting' > /opt/theforeman/tfm/root/usr/share/gems/gems/rails-observers-0.1.2/lib/rails/observers/action_controller/caching/sweeping.rb:73:in
around'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:455:in
public_send' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:455:in
block in make_lambda'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in
block in halting'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in
block in around'
call'
call'
block (2 levels) in halting' > /usr/share/foreman/app/controllers/concerns/application_shared.rb:14:in
set_timezone'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in
block in make_lambda' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in
call'
block in halting' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in
call'
block in around' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in
call'
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in
> /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in
clear_thread' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in
block in halting'
block in around'
call'
call'
around'
block in halting'
block in around'
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:92:in
__run_callbacks__' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in
_run_process_action_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:in
run_callbacks' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:19:in
process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rescue.rb:29:in
process_action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:32:in
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in
block in instrument' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications/instrumenter.rb:20:in
instrument'
instrument' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:30:in
process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/params_wrapper.rb:250:in
process_action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/railties/controller_runtime.rb:18:in
process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:137:in
process' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/rendering.rb:30:in
process'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:196:in
dispatch' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rack_delegation.rb:13:in
dispatch'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:237:in
block in action' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in
call'
dispatch' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:43:in
serve'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:43:in
block in serve' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in
each'
serve' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:815:in
call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.3.7/lib/apipie/static_dispatcher.rb:65:in
call' > /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.3.7/lib/apipie/extractor/recorder.rb:132:in
call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.3.7/lib/apipie/middleware/checksum_in_headers.rb:27:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/etag.rb:24:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/conditionalget.rb:25:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/head.rb:13:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/params_parser.rb:27:in
call' > /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:8:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/flash.rb:260:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:225:in
context'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:220:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/cookies.rb:560:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/query_cache.rb:36:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:29:in
block in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:88:in
run_callbacks'
_run_call_callbacks' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:in
run_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:27:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/remote_ip.rb:78:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/show_exceptions.rb:30:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:38:in
call_app' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:22:in
call'
> /usr/share/foreman/lib/middleware/tagged_logging.rb:18:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/request_id.rb:21:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/methodoverride.rb:22:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/runtime.rb:18:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/cache/strategy/local_cache_middleware.rb:28:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/sendfile.rb:113:in
call' > /opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-3.4.1/lib/secure_headers/middleware.rb:12:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:518:in
call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:165:in
call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in
public_send' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in
method_missing'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:66:in
block in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:in
each'
call' > /usr/share/passenger/phusion_passenger/rack/thread_handler_extension.rb:74:in
process_request'
/usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb:141:in
accept_and_process_next_request' > /usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb:109:in
main_loop'
> /usr/share/passenger/phusion_passenger/request_handler.rb:455:in block (3 levels) in start_threads' > /opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in
call'
`block in create_with_logging_context'
thank you in advance for your help
Aurélien,
