Trouble with UEFI / PXEGrub2 provisioning in 1.13.2
I just received our first UEFI only system, and so far haven't played
with UEFI booting much. I've setup the associations between CentOS 7.2
Operating System and all the grub/grub2 provisioning templates, created a
host that's using PXEGrub2, but the host will not pxeboot. The dhcp lease
is pointing the new host to grub2/grubx64.efi instead of pxelinux.0. The
tftpboot directory has a grub2 folder with the mac specific grub.cfg. When
the system boots, it waits a long time and goes back to the bios boot menu
(not grub2/pxe). The tftp server log shows a request for
grub2/grubx64.efi, with an error for file not found. So, it's looking like
my smart-proxy is not grabbing that file and stuffing it into the grub2
directory. I've turned on debug logging in the proxy and when the build is
initiated, there does not seem to be an attempt to copy the file from
@mediapath /EFI/BOOT/grub2x64.efi.
Has anyone else encountered this? Should I simply copy this file over
manually?
Thank you kindly,
this is expected, when you select PXEGrub2 bootloader, the DHCP option will
not be pxelinux.0.
Our installer was recently enhanced with some support to seetup TFTP UEFI
bootloaders via Puppet, this did not get its way into 1.13 I believe. What
you really need is to copy the bootloader there from your boot partition
(you will need to install grub2-efi for red hat system), or build your own
via grub-mkimage (but this will not work with SecureBoot unless you sign
it). If your proxy is running on Ubuntu or Debian, you need to download
these from repositories (Ubuntu ones are signed, Debian are not).
In the future, we want to distribute bootloaders extracted from main
distributions in a separate package. These will be the official builds
which are also signed (and work via shim). Here are initial builds, you can
use them too.
https://lzap.fedorapeople.org/temp/foreman-bootloaders/
More details at
https://groups.google.com/forum/?fromgroups#!topic/foreman-dev/kEZaJ_8COsU
··· On Mon, Dec 19, 2016 at 9:52 PM, Sean A wrote:
I just received our first UEFI only system, and so far haven’t played
with UEFI booting much. I’ve setup the associations between CentOS 7.2
host that’s using PXEGrub2, but the host will not pxeboot. The dhcp lease
grub2/grubx64.efi, with an error for file not found. So, it’s looking like
directory. I’ve turned on debug logging in the proxy and when the build is
manually?
Thank you kindly,
"Foreman users" group.
Later,
Lukas @lzap Zapletal
> Hello,
> will not be pxelinux.0.
Right… I guess I should have written that the dhcp option was as
expected, I just mentioned it to ensure you all knew it was setup properly.
I was able to copy the grub2x64.efi file from the
@mediapath/EFI/BOOT/grub2x64.efi manually to /var/lib/tftpboot/grub2 and
the provisioning went off with out issue. I guess I just (incorrectly)
expected to see the smart-proxy use the same wget mechanism it uses for the
OS Kernel files to pickup the additional bootloader files.
> use them too.
> <https://www.google.com/url?q=https%3A%2F%2Flzap.fedorapeople.org%2Ftemp%2Fforeman-bootloaders%2F&sa=D&sntz=1&usg=AFQjCNHvfQuGwaP2qt3ApgRyYcN-dVEydQ>
> More details at
Cool, thanks for the update, somehow your post to the list evaded my
searches for information on the grub2 uefi booting.
··· On Thursday, December 22, 2016 at 5:32:28 AM UTC-5, Lukas Zapletal wrote:
On Mon, Dec 19, 2016 at 9:52 PM, Sean A <smal...@gmail.com <javascript:>> > wrote:
manually?
Thank you kindly,
email to foreman-user...@googlegroups.com <javascript:>.
To post to this group, send email to forema...@googlegroups.com
<javascript:>.
Later,
