Hi All
Since the latest version of ubuntu i have found remote execution of puppet run once task fails every time on every managed host.
There seems to be no error or anything.
1: rex login:
2: exit status: 1
What does this actually mean and where do i start looking for where it has broken.
I have checked the credentials on the remote host work. i can ssh from foreman server to the client machine using the stored credentials and i can sudo up using these credentials.
I can also create a script with the commands foreman execute and it works fine
I am at a loss as to what is actually wrong.
