foreman-installer fails on smart proxy with ssl connect errors.
connects properly, like the others have done
3.6 / 4.8 running OS: running EL8
same
running below command (remvoed hostnames) and keep getting error below.
foreman-installer --scenario foreman-proxy-content --certs-tar-file “/root/smart-proxy-certs.tar” --foreman-proxy-register-in-foreman “true” --foreman-proxy-foreman-base-url “https://masterdotcom” --foreman-proxy-trusted-hosts “masterdotcom” --foreman-proxy-trusted-hosts “smart-proxydotcom” --foreman-proxy-oauth-consumer-key “key” --foreman-proxy-oauth-consumer-secret “secret”
it configures through all steps then finally says:
[ERROR ] [configure] Error making POST request to Foreman at https://masterdotcom/api/v2/smart_proxies: Unable to communicate with the proxy: ERF12-2530 [ProxyAPI::ProxyException]: Unable to detect features ([RestClient::SSLCertificateNotVerified]: SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain)) for proxy https://proxydotcom:9090/v2/features Please check the proxy is configured and running on the host.
2023-06-13 13:52:17 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[proxydotcom]/ensure: change from ‘absent’ to ‘present’ failed: Error making POST request to Foreman at https://masterdotcom/api/v2/smart_proxies: Unable to communicate with the proxy: ERF12-2530 [ProxyAPI::ProxyException]: Unable to detect features ([RestClient::SSLCertificateNotVerified]: SSL_connect returned=1 errno=0 state=error: certificate verify failed (self signed certificate in certificate chain)) for proxy https://proxydotcom:9090/v2/features
netstat shows it’s running and listening. Same command but tweaed for the other 2 proxies worked fine
Any ideas?
thanks
