After provisioning a VM using a VMware resource provider image, the host comes up and puppet successfully enrols.
I then wish for my script to hit http://foreman.example.com/unattend/built in order to finish the build process and mark the host as built. Attempting to hit the endpoint from the still-provisioning host results in:
[root@jay-jewel ~]# curl http://foreman.example.com/unattended/built
# unattended: unable to find a host that matches the request from 10.20.30.40
So I’ve got the endpoint right, but foreman doesn’t have the DHCP address as the provisioning address. The “VM” tab correctly identifies the IP address. The “NICs” tab does not show the address.
If i manually complete provisioning, puppet will then go ahead and populate the IP address field under “NICs”
How are others completing VMware image-based builds with cloud-init? It seems the docs for foreman_userdata assume that you’re going to be using a static IP for image-based provisioning.
logs
