I am attempting to provision a machine (unattended). My setup includes the
primary Foreman server and a smart proxy that services the network that
this machine will be built on.
The provisioning template generates the PXE boot file as such
However on the Smart Proxy I am not able to retrieve the KS via that URL. Even if I hit the Foreman server directly I still get a 404. If I hit https://foreman/unattended/provision?hostname=HOSTNAME I can pull down the provisioning template, but that doesn't work through the smart proxy.
I have DNS and DHCP being managed by the smart proxy as well.
Could you provide some logs? Particularly
/var/log/foreman/production.log, would be interesting to see if anything
is logged there when you hit the smart proxy, and also when hitting
Foreman directly. Also /var/log/foreman-proxy/proxy.log for the smart
proxy itself.
One thought is that tokens have a limited duration, and if it's not even
working against Foreman itself, it could have expired. Cancel the build
on the host and press Build again to regenerate it.
On 28/05/15 01:35, Matthew Ceroni wrote:
> Hi:
> the primary Foreman server and a smart proxy that services the network
> that this machine will be built on.
> DEFAULT linux
> LABEL linux
> KERNEL boot/CentOS-6.6-x86_64-vmlinuz
> APPEND initrd=boot/CentOS-6.6-x86_64-initrd.img ks=http://capsule.xxxxxx.net:8000/unattended/provision?token=1d528253-8884-4ca9-84d9-a3b6cd0657bf ksdevice=bootif network kssendmac
> IPAPPEND 2
Looks like your installer did not configure templates plugin.
WORKAROUND: Re-run capsule installer with --capsule-templates true or
edit /etc/foreman-proxy/setting.d/templates.yml and enable there, make
sure the URL is set properly (http not https, valid capsule FQDN and
port 8000 not 9090).
