> From: "Tom K." <tn@to3.de>
> To: "Foreman users" <foreman-users@googlegroups.com>
> Sent: Wednesday, July 27, 2016 10:17:12 AM
> Subject: [foreman-users] undefined method join' for #<String>, receiving salt states from smartproxy > > Hi, > > I've a running Foreman 1.11.3 and a Smartyproxy 1.11.3 on 2 different > machines. The Smartproxy serves the salt-api/saltmaster. Now, if I query > from Foreman the states of the Saltmaster SmartyProxy, nothing happens. > > Sometimes a popup appears with the message > > Error: ERF12-4701 [ProxyAPI::ProxyException]: Unable to fetch Salt states > list ([ProxyAPI::ProxyException]: ERF12-7301 [ProxyAPI::ProxyException]: > Unable to fetch Salt environments list ([RestCli...) for proxy > https:/fosp-saltmaster-001:8443/salt/ > > > In the *forman-proxy.log* on the smartproxy tells me > > E, [2016-07-27T10:05:26.163632 #2422] ERROR -- : undefined method
join'
> for #<String:0x007f81e43cbd70> (NoMethodError)
> /usr/share/gems/gems/sinatra-1.3.5/lib/sinatra/showexceptions.rb:37:in
> rescue in call' > /usr/share/gems/gems/sinatra-1.3.5/lib/sinatra/showexceptions.rb:21:in >
call'
> /usr/share/gems/gems/sinatra-1.3.5/lib/sinatra/base.rb:124:in call' > /usr/share/gems/gems/sinatra-1.3.5/lib/sinatra/base.rb:1417:in
block in
> call'
> /usr/share/gems/gems/sinatra-1.3.5/lib/sinatra/base.rb:1499:in synchronize' > /usr/share/gems/gems/sinatra-1.3.5/lib/sinatra/base.rb:1417:in
call'
> /usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in block in call' > /usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in
each'
> /usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in call' > /usr/share/gems/gems/rack-1.6.4/lib/rack/builder.rb:153:in
call'
> /usr/share/gems/gems/rack-1.6.4/lib/rack/handler/webrick.rb:88:in service' > /usr/share/ruby/webrick/httpserver.rb:138:in
service'
> /usr/share/ruby/webrick/httpserver.rb:94:in run' > /usr/share/ruby/webrick/server.rb:295:in
block in start_thread'
> The /var/log/foreman/production.log throws
> 2016-07-27 10:10:48 [app] [W] ProxyAPI operation FAILED
> > ProxyAPI::ProxyException: ERF12-4701 [ProxyAPI::ProxyException]: Unable
> to fetch Salt states list ([ProxyAPI::ProxyException]: ERF12-7301
> [ProxyAPI::ProxyException]: Unable to fetch Salt environments list
> ([RestCli…) for proxy https:/fosp-saltmaster-001:8443/salt/
> /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_salt-5.0.1/app/lib/proxy_api/salt.rb:43:in
> rescue in states_list' > > > /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_salt-5.0.1/app/lib/proxy_api/salt.rb:35:in >
states_list'
> /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_salt-5.0.1/app/controllers/foreman_salt/state_importer.rb:16:in
> fetch_states_from_proxy' > > > /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_salt-5.0.1/app/controllers/foreman_salt/salt_modules_controller.rb:60:in >
import'
> /opt/rh/rh-ror41/root/usr/share/gems/gems/actionpack-4.1.5/lib/action_controller/metal/implicit_render.rb:4:in
> send_action' > > > /opt/rh/rh-ror41/root/usr/share/gems/gems/actionpack-4.1.5/lib/abstract_controller/base.rb:189:in >
process_action'
> /opt/rh/rh-ror41/root/usr/share/gems/gems/actionpack-4.1.5/lib/action_controller/metal/rendering.rb:10:in
> process_action' > > > /opt/rh/rh-ror41/root/usr/share/gems/gems/actionpack-4.1.5/lib/abstract_controller/callbacks.rb:20:in >
block in process_action'
> /opt/rh/rh-ror41/root/usr/share/gems/gems/activesupport-4.1.5/lib/active_support/callbacks.rb:113:in
> call' > > > /opt/rh/rh-ror41/root/usr/share/gems/gems/activesupport-4.1.5/lib/active_support/callbacks.rb:113:in >
call'
> /opt/rh/rh-ror41/root/usr/share/gems/gems/activesupport-4.1.5/lib/active_support/callbacks.rb:149:in
> block in halting_and_conditional' > > > /opt/rh/rh-ror41/root/usr/share/gems/gems/activesupport-4.1.5/lib/active_support/callbacks.rb:149:in >
call'
call'
call'
> What's my problem? What can I do… I've really no idea…
Fetching the salt environment or salt states list requires the proxy be configured to talk to the salt-api. See section 2.1.3
in the latest manual: Foreman :: Plugin documentation index
Troubleshooting steps:
- Look in /var/log/foreman-proxy/proxy.log, and /var/log/salt/* for any errors.
- Does the API user have the @runner permission in /etc/salt/master?
- Is the salt-api service started?
- Is /etc/foreman-proxy/settings.d/salt.yml configured to connect to the right place?
From ERF12-4701 - Foreman.
- Stephen
----- Original Message -----Thanks,
Tom
"Foreman users" group.
