I am not able to run unit tests on my Fedora 18 laptop with rbenv 1.9
ruby.
I did complete cleanup of ~/.gem directory, I did complete cleanup of my
rbenv (new installation), compiled Ruby, installed Bundler and all the
dependencies, but I am getting:
[lzap@lzapx smart-proxy]$ rake test
/home/lzap/.rbenv/versions/1.9.3-p385/bin/ruby -I"lib:.:lib:test" -I"/home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib" "/home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb" "test/bmc_api_test.rb" "test/bmc_test.rb" "test/proxy_test.rb" "test/puppet_api_test.rb" "test/puppet_class_test.rb" "test/puppet_environment_test.rb" "test/puppetca_test.rb" "test/record_test.rb" "test/server_test.rb" "test/subnet_test.rb" "test/tftp_test.rb" "test/util_test.rb"
/home/lzap/CloudForms/smart-proxy/lib/proxy/settings.rb:8:in method_missing': wrong number of arguments (2 for 1) (ArgumentError) from /home/lzap/CloudForms/smart-proxy/test/test_helper.rb:7:inblock in <top (required)>'
from /home/lzap/CloudForms/smart-proxy/test/test_helper.rb:7:in each' from /home/lzap/CloudForms/smart-proxy/test/test_helper.rb:7:in<top (required)>'
from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in require' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:inrequire'
from /home/lzap/CloudForms/smart-proxy/test/bmc_api_test.rb:1:in <top (required)>' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:inrequire'
from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in require' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb:15:inblock in <main>'
from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb:4:in select' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb:4:in<main>'
I have been playing with this for the whole day now and I don't know what
can be possibly wrong.
The big question now is - why it does not work on the very same Ruby
version + all the deps while it is confirmed to be working by other
developers?
I will need to install clean Fedora 18 tomorrow to see if this is some
Fedora 18 issue, or just something wrong on my setup.
> Hello,
> ruby.
can you try bundle exec rake?
Ohad
“test/bmc_api_test.rb” “test/bmc_test.rb” “test/proxy_test.rb”
“test/puppet_api_test.rb” “test/puppet_class_test.rb”
“test/puppet_environment_test.rb” “test/puppetca_test.rb”
“test/record_test.rb” “test/server_test.rb” “test/subnet_test.rb”
“test/tftp_test.rb” “test/util_test.rb”
(required)>'
from
/home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in require' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:inrequire’
from /home/lzap/CloudForms/smart-proxy/test/bmc_api_test.rb:1:in <top (required)>' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:inrequire’
from
/home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in require' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb:15:inblock in ‘
from
/home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb:4:in select' from /home/lzap/.rbenv/versions/1.9.3-p385/lib/ruby/gems/1.9.1/gems/rake-10.0.4/lib/rake/rake_test_loader.rb:4:in’
I have been playing with this for the whole day now and I don’t know what
developers?
