> > >> > The "Test failures on Ruby 2.2" ticket at
> > >> > Bug #12219: Test failures on Ruby 2.2 - Foreman must be fixed too so
that
> > >> > 2.2 can be added to our test matrix and we can package safely
against
> > >> > that version.
> > > I’ll pick it up. Two failures around skipped tests are easy to deal
> > > with; will see what the hostname failure is about.
> > Thanks Dmitri. The failure on PostgreSQL loading the library version is
> > also rather concerning, but it seemed very consistent. I haven't tried
> > to reproduce it locally yet, so shout if you struggle to do so.
> I can't reproduce that bug anymore, on the Rails 4 branch tests on
postgres
> & Ruby 2.2 seem to pass just like the rest.
> Last thursday we had a call with Katello developers working on Rails 4
> as well and it seems like all major projects should be ready. The PR in
> core https://github.com/theforeman/foreman/pull/2870 passes w/o the
> memory issues it used to have, and Katello seems to be consistently
> green as well.
> We proposed Tuesday Dec 15th as the merge day, the reason being that
> right now it can be merged, and delaying it more means delaying other
> big features coming in such as facets or Patternfly.
> Not to mention maintaining the rails4 branch and all projects passing
> tests in sync is a burden on some developers that we can get rid of
> quickly after merging.
> Third, the sooner we get this in, the more testing it will get before
> 1.11. I will move my local 'production' foreman to nightly to iron out
> possible common bugs
> Does that sound good, is there anything anyone would like to do before
> merging, etc? If not, let's not merge any major changes on Monday and
> let's tackle this on Tuesday asap. Is there anyone that can merge Rails
> 4 on Katello in any European timezone?
No, but we could coordinate to work earlier EST to maximize crossover
between all developers to address any issues.
On Dec 12, 2015 12:18 PM, "Daniel Lobato Garcia" wrote:
> On 11/11, Dominic Cleal wrote:
> > On 11/11/15 12:19, Dmitri Dolguikh wrote:
> > > On Wed, Nov 11, 2015 at 12:10 PM, Dominic Cleal wrote:
> that
> against
> > >> > that version.
> I can't reproduce that bug anymore, on the Rails 4 branch tests on postgres
> green as well.
> Does that sound good?
+1
Ohad
merging, etc? If not, let’s not merge any major changes on Monday and
let’s tackle this on Tuesday asap. Is there anyone that can merge Rails
against
that version.
also rather concerning, but it seemed very consistent. I haven’t tried
I can’t reproduce that bug anymore, on the Rails 4 branch tests on postgres
green as well.
1.11. I will move my local ‘production’ foreman to nightly to iron out
>>>>> Bug #12219: Test failures on Ruby 2.2 - Foreman must be fixed too so that
>>>>> 2.2 can be added to our test matrix and we can package safely against
>>>>> that version.
The PostgreSQL test appears to still fail with a vaguely similar error:
bundle exec rake db:drop db:create db:migrate
Could not load 'active_record/connection_adapters/postgresql_adapter'.
Make sure that the adapter in config/database.yml is valid. If you use
an adapter other than 'mysql', 'mysql2', 'postgresql' or 'sqlite3' add
the necessary adapter gem to the Gemfile.
/usr/local/rvm/gems/ruby-2.2.3@test_develop_pr_core_ruby22-1/gems/activesupport-4.1.5/lib/active_support/dependencies.rb:247:in
`require'
The three test case failures are gone on your Rails 4 branch.
> green as well.
The review isn't complete, I'll only be merging it when that's done. I
also won't do it at the same time as the 1.10.0 release to ensure one
doesn't disrupt the other.
1.10.0 has got another important ticket (#12794) assigned and in
progress, but I really hope it will be sorted in the next day or two.
that version.
postgres
Could not load ‘active_record/connection_adapters/postgresql_adapter’.
an adapter other than ‘mysql’, ‘mysql2’, ‘postgresql’ or ‘sqlite3’ add
`require’
green as well.
The review isn’t complete, I’ll only be merging it when that’s done. I
also won’t do it at the same time as the 1.10.0 release to ensure one
doesn’t disrupt the other.
> What versions of Ruby will be supported/tested against once this work is
> merged?
The Rails PR doesn't change the supported Ruby versions, so it's
unchanged from 1.9.3, 2.0.0 and 2.1.
Once #12219 is fixed, then Ruby 2.2 can also be tested and supported.
> I am not familiar with the Debian side of available Rails versions.
Debian packages use the Rails version specified in the Gemfile, via a
vendored directory of gems. They use a range of Ruby versions from
1.9.3 to 2.1, depending on the release. #8884 tracks (eventually)
dropping Ruby 1.9.3 support.
I tried installing 2.2.3 and 2.2.2, then running the very same command
jenkins runs (bundle exec rake db:drop db:create db:migrate) and it
worked without any problems.
Not saying it's this, but somebody with a similar problem on
stackoverflow solved the issue by reinstalling that ruby version, whose
gemset might have been corrupted.
> >>>>> http://projects.theforeman.org/issues/12219 must be fixed too so that
> >>>>> that version.
> + bundle exec rake db:drop db:create db:migrate
> `require'
> (http://ci.theforeman.org/job/test_develop_pr_core_ruby22/8/database=postgresql,ruby=2.2/console)
All tests passing. Compatible with ruby 1.9.3, 2.0.x, 2.1.x, and 2.2.x
We are ready to coordinate with the foreman core devs to merge in tandem.
Chris
On Monday, December 14, 2015 at 11:01:35 AM UTC-5, Dominic Cleal wrote:
> > merged?
> Dominic Cleal
> dom...@cleal.org
> Katello rails 4 is ready to merge.
> great news!
On Wed, Dec 16, 2015 at 12:03 AM, wrote:
> Chris
>> is
>> > merged?
>> Dominic Cleal
>> dom...@cleal.org
> "foreman-dev" group.
> email to foreman-dev+unsubscribe@googlegroups.com.
