Problem: “Updates” repository showing zero content under content view
Expected outcome: “Updates” repository should show packages under content
Foreman and Proxy versions: Foreman/Foreman-katello 3.1.2
Distribution and version: CentOS 7.9
One of my repository (updates from Centos) is showing zero contents under content view ,
I had added that repo under Lifecycle Environment.
In Products i can see packages showing count and got updated as well under product “Centos7” , I have attached snippet for the same.
Please check and guide me , am i missing any step for the same.
Due to this all my hosts are showing zero packages for “updates” Repositories.
That is not expected. Do you see any RPMs from the repository in the RPM Packages subtab?
Also can you check the same on the /legacy/content_views/‘cv_id’ URL path if possible to verify it’s not a new UI issue. If you don’t see RPMs of the repo in the CV version, could you check if the publish task for the CV succeeded?
i resolved this issue by deleting said content view and recreated new one.
After this i was able to see all repository packages count under content tab.
Still it’s mystery why count was showing zero.
