Hi All,
I am running Scientific Linux 6.5:
Today I updated Foreman from 1.3 to 1.4 following the directions at
http://www.theforeman.org/manuals/1.4/index.html#3.6Upgrade . I also ran
yum update -y
and rebooted the server. Overall, the upgrade was very
simple.
The new software levels are:
RELEASE: Scientific Linux release 6.5 (Carbon)
FOREMAN: 1.4.2
RUBY: ruby 1.8.7 (2011-06-30 patchlevel 352) [x86_64-linux]
PUPPET: 3.5.1
Now puppet
on my Foreman host fails for many commands. I can't tell if
this problem is related to the Foreman upgrade, but I'm hoping that someone
else here is familiar with this problem or can point me in the correct
direction.
Here are two example failures.
[root@host ~]# puppet resource group puppet
Failed to load feature test for libuser: uninitialized constant
Puppet::FileSystem::File
group { 'puppet':
ensure => 'present',
gid => '52',
[root@host ~]#
[root@host ~]# puppet agent --test
Error: /File[/etc/puppet]: Could not evaluate: uninitialized constant
Error: /File[/var/lib/puppet]: Could not evaluate: uninitialized constant
Notice: /File[/var/lib/puppet/facts.d]: Dependency File[/var/lib/puppet]
has failures: true
Warning: /File[/var/lib/puppet/state/last_run_summary.yaml]: Skipping
because of failed dependencies
Error: Could not prepare for execution: Got 4 failure(s) while
initializing: File[/var/log/puppet]: uninitialized constant
Puppet::FileSystem::File; File[/var/lib/puppet]: uninitialized constant
Puppet::FileSystem::File; File[/etc/puppet]: uninitialized constant
Puppet::FileSystem::File; File[/var/run/puppet]: uninitialized constant
[root@host ~]#
Any ideas?
Thank you,
-= Stefan
This seems to be more of a Puppet error instead of a foreman error.
I worked around this problem by downgrading from Puppet 3.5 to 3.5, using
this command:
yum downgrade puppet-server-3.4.3-1.el6 puppet-3.4.3-1.el6
I believe that I ran into the following Puppet bug:
https://tickets.puppetlabs.com/browse/PUP-1603
-= Stefan
On Monday, April 21, 2014 4:34:01 PM UTC-7, Stefan Lasiewski wrote:
> Hi All,
> `yum update -y` and rebooted the server. Overall, the upgrade was very
> simple.
> FOREMAN: 1.4.2
> PUPPET: 3.5.1
> Now `puppet` on my Foreman host fails for many commands. I can't tell if
> direction.
> group { 'puppet':
> gid => '52',
> [root@host ~]#
> has failures: true
> [root@host ~]#
> Any ideas?
> Thank you,
> -= Stefan
