All,
Previous Foreman upgrades, to currently running version 1.16, have always gone fine. However, trying to upgrade to 1.17 (and beyond) fails. After following the upgrade instructions in the manual, I run “foreman-rake db:migrate”. Here’s the output generated from the command:
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-4.20.0/lib/sequel/database/schema_generator.rb:19: warning: constant ::Fixnum is deprecated
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-4.20.0/lib/sequel/database/schema_generator.rb:19: warning: constant ::Bignum is deprecated
/usr/share/foreman/lib/core_extensions.rb:183: warning: already initialized constant ActiveSupport::MessageEncryptor::DEFAULT_CIPHER
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/message_encryptor.rb:22: warning: previous definition of DEFAULT_CIPHER was here
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
rake aborted!
NoMethodError: undefined method `alias_method_chain' for HostsController:Class
Did you mean? alias_method
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_host_rundeck-0.0.2/app/controllers/concerns/foreman_host_rundeck/hosts_controller_extensions.rb:6:in `block in <module:HostsControllerExtensions>'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/concern.rb:120:in `class_eval'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/concern.rb:120:in `append_features'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_host_rundeck-0.0.2/lib/foreman_host_rundeck/engine.rb:21:in `include'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_host_rundeck-0.0.2/lib/foreman_host_rundeck/engine.rb:21:in `block in <class:Engine>'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:413:in `instance_exec'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:413:in `block in make_lambda'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:197:in `block (2 levels) in halting'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:601:in `block (2 levels) in default_terminator'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:600:in `catch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:600:in `block in default_terminator'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:198:in `block in halting'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:507:in `block in invoke_before'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:507:in `each'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:507:in `invoke_before'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:130:in `run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/reloader.rb:87:in `prepare!'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/application/finisher.rb:61:in `block in <module:Finisher>'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/initializable.rb:30:in `instance_exec'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/initializable.rb:30:in `run'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/initializable.rb:59:in `block in run_initializers'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/initializable.rb:48:in `each'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/initializable.rb:48:in `tsort_each_child'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/initializable.rb:58:in `run_initializers'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/application.rb:353:in `initialize!'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>'
/opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in `block in require'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:258:in `load_dependency'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/dependencies.rb:292:in `require'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/application.rb:329:in `require_environment!'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.4/lib/rails/application.rb:445:in `block in run_tasks_blocks'
/opt/rh/rh-ruby24/root/usr/share/gems/gems/rake-12.0.0/exe/rake:27:in `<top (required)>'
Tasks: TOP => db:migrate => environment
I’ve searched high-and-low for a solution, and tried lots of things, but no joy. Help would be greatly appreciated.
