Greetings,
For host collections and activation keys we use a value of -1 for the content host limit to represent the idea of unlimited content hosts. I think this is confusing to the API users and greatly complicates the UI, causing edge cases (see Bug #6078: -1 should not be used to represent "unlimited" for activation keys and host collections - Katello - Foreman and Bug #5163: System group limit of -1 is accepted - Katello - Foreman).
I would like to propose that we stop using -1 to mean "Unlimited" and instead just use an "unlimited" boolean on the relevant object. If the boolean is true than the content host limit is ignored, otherwise it represents the content host limit. This is what I've had to do in the UI anyway to fix these issues.
Thoughts?
Walden
i am in favor of this proposal. +1
----- Original Message -----
> Greetings,
> cases (see http://projects.theforeman.org/issues/6078 and
> http://projects.theforeman.org/issues/5163).
> these issues.
> Thoughts?
> Thanks,
> Walden
> "foreman-dev" group.
> email to foreman-dev+unsubscribe@googlegroups.com.
Good with me. Don't forget to also change the apipie and hammer commands.
> Greetings,
> these issues.
> Thoughts?
> Thanks,
> Walden
Last call for comments, I am going to start working on this this week.
Walden
To: foreman-dev@googlegroups.com
Sent: Tuesday, June 17, 2014 2:51:14 PM
Subject: Re: [foreman-dev] Using -1 as "Unlimited"
Greetings,
I would like to propose that we stop using -1 to mean “Unlimited” and instead
just use an “unlimited” boolean on the relevant object. If the boolean is
content host limit. This is what I’ve had to do in the UI anyway to fix
these issues.
Thoughts?
Walden
Good with me. Don’t forget to also change the apipie and hammer commands.
You received this message because you are subscribed to the Google Groups “foreman-dev” group.
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
