Using defined types in foreman to create instance
Please help.
For example:
How i can pass parameters to defined puppet type *apache::vhost *and create
instance from foreman :
Definition: apache::vhost
··· # # This class installs Apache Virtual Hosts # # Parameters: # - The $port to configure the host on # - The $docroot provides the DocumentationRoot variable # - The $template option specifies whether to use the default template or override # - The $priority of the site # - The $serveraliases of the site # - The $options for the given vhost # - The $vhost_name for name based virtualhosting, defaulting to * # # Actions: # - Install Apache Virtual Hosts # # Requires: # - The apache class # # Sample Usage: # apache::vhost { 'site.name.fqdn': # priority => '20', # port => '80', # docroot => '/path/to/docroot', # }
define apache::vhost(
$port,
$docroot,
$template = ‘apache/vhost-default.conf.erb’,
$priority = ‘25’,
$servername = ‘’,
$serveraliases = ‘’,
$options = “Indexes FollowSymLinks MultiViews”,
$vhost_name = ‘*’
include apache
Below is a pre-2.6.5 idiom for having a parameter default to the title,
but you could also just declare $servername = “$title” in the parameters
list and change srvname to servername in the template.
if $servername == ‘’ {
$srvname = $title
} else {
$srvname = $servername
case $operatingsystem {
‘centos’, ‘redhat’, ‘fedora’: { $vdir = ‘/etc/httpd/conf.d’
$logdir = ‘/var/log/httpd’}
‘ubuntu’, ‘debian’: { $vdir = ‘/etc/apache2/sites-enabled’
$logdir = ‘/var/log/apache2’}
default: { $vdir = ‘/etc/apache2/sites-enabled’
file {
"${vdir}/${priority}-${name}.conf":
content => template($template),
owner => ‘root’,
group => ‘root’,
mode => ‘755’,
require => Package[‘httpd’],
notify => Service[‘httpd’],
With regards, Vladislav.
Use hiera or foreman to fill in all those variables. You could auto
populate with defined types and puppet 3 and foreman to.
··· On Feb 13, 2013 11:29 AM, "Vlados Vlados" wrote:
Please help.
For example:
create instance from foreman :
Parameters:
override
Actions:
Requires:
- The apache class
Sample Usage:
apache::vhost { ‘site.name.fqdn’:
priority => ‘20’,
port => ‘80’,
docroot => ‘/path/to/docroot’,
$port,
$docroot,
$priority = ‘25’,
$servername = ‘’,
$vhost_name = ‘*’
include apache
$srvname = $title
} else {
file {
owner => ‘root’,
group => ‘root’,
mode => ‘755’,
"Foreman users" group.
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
You can't instantiate resources (defined types, or native) over the
Puppet ENC interface. Maybe use create_resources instead, e.g.
define foo($a, $b) {
notify { "$title: got $a and $b": }
class createfoo($data){
create_resources(foo, $data)
Then in foreman for the createfoo class, set the data parameter to:
··· On 13/02/13 17:29, Vlados Vlados wrote: > Please help. > For example: > How i can pass parameters to defined puppet type *apache::vhost *and > create instance from foreman :
data:
first:
a: "param 1a"
b: "param 1b"
second:
a: "param 2a"
b: “param 2b”
Dominic Cleal
Red Hat Engineering
Hi Vlados,
Can you show me how you solve your problem ? I a facing the same issue but
I don't know how to set the varibles in foreman.
Regards.
··· Le mercredi 13 février 2013 18:29:00 UTC+1, Vlados Vladosov a écrit : > > Please help. > For example: > How i can pass parameters to defined puppet type *apache::vhost *and > create instance from foreman : > > > > > # Definition: apache::vhost > # > # This class installs Apache Virtual Hosts > # > # Parameters: > # - The $port to configure the host on > # - The $docroot provides the DocumentationRoot variable > # - The $template option specifies whether to use the default template or > override > # - The $priority of the site > # - The $serveraliases of the site > # - The $options for the given vhost > # - The $vhost_name for name based virtualhosting, defaulting to * > # > # Actions: > # - Install Apache Virtual Hosts > # > # Requires: > # - The apache class > # > # Sample Usage: > # apache::vhost { 'site.name.fqdn': > # priority => '20', > # port => '80', > # docroot => '/path/to/docroot', > # } > > > define apache::vhost( > $port, > $docroot, > $template = 'apache/vhost-default.conf.erb', > $priority = '25', > $servername = '', > $serveraliases = '', > $options = "Indexes FollowSymLinks MultiViews", > $vhost_name = '*' > ) { > > include apache > > # Below is a pre-2.6.5 idiom for having a parameter default to the title, > # but you could also just declare $servername = "$title" in the parameters > # list and change srvname to servername in the template. > > if $servername == '' { > $srvname = $title > } else { > $srvname = $servername > } > case $operatingsystem { > 'centos', 'redhat', 'fedora': { $vdir = '/etc/httpd/conf.d' > $logdir = '/var/log/httpd'} > 'ubuntu', 'debian': { $vdir = '/etc/apache2/sites-enabled' > $logdir = '/var/log/apache2'} > default: { $vdir = '/etc/apache2/sites-enabled' > $logdir = '/var/log/apache2'} > } > file { > "${vdir}/${priority}-${name}.conf": > content => template($template), > owner => 'root', > group => 'root', > mode => '755', > require => Package['httpd'], > notify => Service['httpd'], > } > > } > > > > > With regards, Vladislav. > >
Cool, thank you!
··· среда, 13 февраля 2013 г., 21:31:32 UTC+4 пользователь Dominic Cleal написал: > > On 13/02/13 17:29, Vlados Vlados wrote: > > Please help. > > For example: > > How i can pass parameters to defined puppet type *apache::vhost *and > > create instance from foreman : > > You can't instantiate resources (defined types, or native) over the > Puppet ENC interface. Maybe use create_resources instead, e.g. > > define foo($a, $b) { > notify { "$title: got $a and $b": } > } > > class createfoo($data){ > create_resources(foo, $data) > } > > Then in foreman for the createfoo class, set the data parameter to: > > --- > data: > first: > a: "param 1a" > b: "param 1b" > second: > a: "param 2a" > b: "param 2b" > > -- > Dominic Cleal > Red Hat Engineering >
Hi
Everybody solve the problem ?
I kknow is very old, but i have the same problem today
thx
··· Le jeudi 13 mars 2014 09:58:49 UTC+1, James James a écrit : > > Hi Vlados, > > Can you show me how you solve your problem ? I a facing the same issue but > I don't know how to set the varibles in foreman. > > > Regards. > > > Le mercredi 13 février 2013 18:29:00 UTC+1, Vlados Vladosov a écrit : >> >> Please help. >> For example: >> How i can pass parameters to defined puppet type *apache::vhost *and >> create instance from foreman : >> >> >> >> >> # Definition: apache::vhost >> # >> # This class installs Apache Virtual Hosts >> # >> # Parameters: >> # - The $port to configure the host on >> # - The $docroot provides the DocumentationRoot variable >> # - The $template option specifies whether to use the default template or >> override >> # - The $priority of the site >> # - The $serveraliases of the site >> # - The $options for the given vhost >> # - The $vhost_name for name based virtualhosting, defaulting to * >> # >> # Actions: >> # - Install Apache Virtual Hosts >> # >> # Requires: >> # - The apache class >> # >> # Sample Usage: >> # apache::vhost { 'site.name.fqdn': >> # priority => '20', >> # port => '80', >> # docroot => '/path/to/docroot', >> # } >> >> >> define apache::vhost( >> $port, >> $docroot, >> $template = 'apache/vhost-default.conf.erb', >> $priority = '25', >> $servername = '', >> $serveraliases = '', >> $options = "Indexes FollowSymLinks MultiViews", >> $vhost_name = '*' >> ) { >> >> include apache >> >> # Below is a pre-2.6.5 idiom for having a parameter default to the title, >> # but you could also just declare $servername = "$title" in the parameters >> # list and change srvname to servername in the template. >> >> if $servername == '' { >> $srvname = $title >> } else { >> $srvname = $servername >> } >> case $operatingsystem { >> 'centos', 'redhat', 'fedora': { $vdir = '/etc/httpd/conf.d' >> $logdir = '/var/log/httpd'} >> 'ubuntu', 'debian': { $vdir = '/etc/apache2/sites-enabled' >> $logdir = '/var/log/apache2'} >> default: { $vdir = '/etc/apache2/sites-enabled' >> $logdir = '/var/log/apache2'} >> } >> file { >> "${vdir}/${priority}-${name}.conf": >> content => template($template), >> owner => 'root', >> group => 'root', >> mode => '755', >> require => Package['httpd'], >> notify => Service['httpd'], >> } >> >> } >> >> >> >> >> With regards, Vladislav. >> >>
I have solved my problem so can you explain me yours ?
··· 2014-05-12 14:20 GMT+02:00 Damien Mathieu :
Hi
thx
Hi Vlados,
but I don’t know how to set the varibles in foreman.
Regards.
Please help.
For example:
Parameters:
or override
Actions:
Requires:
- The apache class
Sample Usage:
priority => ‘20’,
port => ‘80’,
$port,
$docroot,
$priority = ‘25’,
$servername = ‘’,
$vhost_name = ‘*’
include apache
title,
parameters
$srvname = $title
} else {
file {
owner => ‘root’,
group => ‘root’,
mode => ‘755’,
https://groups.google.com/d/topic/foreman-users/o-Sqjo-n21A/unsubscribe.
I have created a puppet module
(https://github.com/soumentrivedi/foreman_resources) to achieve this.
I have imported this module into my Foreman instance, performed the
required setup for Puppet Future Parser (mentioned in the Readme of the
module) and tested this Puppetlabs postgresql module. All looks ok and
works fine. I have given a sample yaml example as well for how to pass
values.
I am sure there might be many more slicker ways in achieving this, the
current solution works for us perfectly fine.
Feedback on the module is always welcome. :slight_smile:
··· On Wednesday, July 16, 2014 9:59:27 PM UTC+1, James James wrote: > > Hi, > > I have solved my problem so can you explain me yours ? > > > 2014-05-12 14:20 GMT+02:00 Damien Mathieu >: > >> Hi >> >> Everybody solve the problem ? >> >> I kknow is very old, but i have the same problem today >> >> thx >> >> Le jeudi 13 mars 2014 09:58:49 UTC+1, James James a écrit : >> >>> Hi Vlados, >>> >>> Can you show me how you solve your problem ? I a facing the same issue >>> but I don't know how to set the varibles in foreman. >>> >>> >>> Regards. >>> >>> >>> Le mercredi 13 février 2013 18:29:00 UTC+1, Vlados Vladosov a écrit : >>>> >>>> Please help. >>>> For example: >>>> How i can pass parameters to defined puppet type *apache::vhost *and >>>> create instance from foreman : >>>> >>>> >>>> >>>> >>>> # Definition: apache::vhost >>>> # >>>> # This class installs Apache Virtual Hosts >>>> # >>>> # Parameters: >>>> # - The $port to configure the host on >>>> # - The $docroot provides the DocumentationRoot variable >>>> # - The $template option specifies whether to use the default template >>>> or override >>>> # - The $priority of the site >>>> # - The $serveraliases of the site >>>> # - The $options for the given vhost >>>> # - The $vhost_name for name based virtualhosting, defaulting to * >>>> # >>>> # Actions: >>>> # - Install Apache Virtual Hosts >>>> # >>>> # Requires: >>>> # - The apache class >>>> # >>>> # Sample Usage: >>>> # apache::vhost { 'site.name.fqdn': >>>> # priority => '20', >>>> # port => '80', >>>> # docroot => '/path/to/docroot', >>>> # } >>>> >>>> >>>> define apache::vhost( >>>> $port, >>>> $docroot, >>>> $template = 'apache/vhost-default.conf.erb', >>>> $priority = '25', >>>> $servername = '', >>>> $serveraliases = '', >>>> $options = "Indexes FollowSymLinks MultiViews", >>>> $vhost_name = '*' >>>> ) { >>>> >>>> include apache >>>> >>>> # Below is a pre-2.6.5 idiom for having a parameter default to the >>>> title, >>>> # but you could also just declare $servername = "$title" in the >>>> parameters >>>> # list and change srvname to servername in the template. >>>> >>>> if $servername == '' { >>>> $srvname = $title >>>> } else { >>>> $srvname = $servername >>>> } >>>> case $operatingsystem { >>>> 'centos', 'redhat', 'fedora': { $vdir = '/etc/httpd/conf.d' >>>> $logdir = '/var/log/httpd'} >>>> 'ubuntu', 'debian': { $vdir = '/etc/apache2/sites-enabled' >>>> $logdir = '/var/log/apache2'} >>>> default: { $vdir = '/etc/apache2/sites-enabled' >>>> $logdir = '/var/log/apache2'} >>>> } >>>> file { >>>> "${vdir}/${priority}-${name}.conf": >>>> content => template($template), >>>> owner => 'root', >>>> group => 'root', >>>> mode => '755', >>>> require => Package['httpd'], >>>> notify => Service['httpd'], >>>> } >>>> >>>> } >>>> >>>> >>>> >>>> >>>> With regards, Vladislav. >>>> >>>> -- >> You received this message because you are subscribed to a topic in the >> Google Groups "Foreman users" group. >> To unsubscribe from this topic, visit >> https://groups.google.com/d/topic/foreman-users/o-Sqjo-n21A/unsubscribe. >> To unsubscribe from this group and all its topics, send an email to >> foreman-user...@googlegroups.com . >> To post to this group, send email to forema...@googlegroups.com >> . >> Visit this group at http://groups.google.com/group/foreman-users. >> For more options, visit https://groups.google.com/d/optout. >> > >
