Does anyone uses Hiera as well as puppet smart classes both ? i want to
use Hiera for my infrastructure modules and want to give puppet smart
classes for application teams modules, does that creates any issues, let me
know if someone have experience or suggestion with this?
Regards,
DJ
Ought to be fine. Puppet data binding (Hiera) is used if no parameter
is given from the ENC, i.e. when you don't override it, or you tick the
"Use Puppet default" checkbox.
On 08/07/15 18:47, Unix SA wrote:
> Hello,
> me know if someone have experience or suggestion with this?
Dominic Cleal
Red Hat Engineering
Hi
We use Hiera alot. Actually we also use smart variables, but only to define
Hiera levels (define roles clusters etc).
Recently we ve opensourced a foreman-hiera-lookup plugin to foreman. This
plugin helps us with an easy acces to varibles from Foreman UI while
keeping evrything under the version control.
https://github.com/ingenico-group/foreman_hiera_lookup
Regards,
Iakov
On Wednesday, July 8, 2015 at 7:47:36 PM UTC+2, Unix SA wrote:
> Hello,
> Regards,
> DJ
great, i want my application teams to use smart classes as they will have
easy interface to use and permissioning and infrastructure modules will use
Hiera as they provide version control and simpler hierarchy and not class
level hierarchy …
> > Hello,
> Dominic Cleal
> Red Hat Engineering
