I am trying to mirror a local repo using katello, latest from git. Pulp
is pulp-server-2.3.0-0.16.alpha.fc19.noarch. I am getting the exception at
http://fpaste.org/72135/08577421/
I have pulp-rpm-yumplugins-2.3.0-0.16.alpha.fc19.noarch which I assume
gives me that distributor?
– bk
can you do a:
rpm -qa "pulp" | sort
and paste that? the yum distributor is actually in:
pulp-rpm-plugins
rpm -ql pulp-rpm-plugins-2.3.1-1.el6.noarch |grep yum_distributor
/usr/lib/pulp/plugins/distributors/yum_distributor
Mike
> -- bk
Mike McCune
mmccune AT redhat.com
Red Hat Engineering | Portland, OR
Systems Management | 650-254-4248
I do have that installed. Could I have missd a config?
[bkearney@bkearney x86_64]$ rpm -qa "pulp" | sort
pulp-admin-client-2.3.0-0.16.alpha.fc19.noarch
pulp-katello-plugins-0.2-1.fc19.noarch
pulp-puppet-plugins-2.3.0-0.16.alpha.fc19.noarch
pulp-rpm-admin-extensions-2.3.0-0.16.alpha.fc19.noarch
pulp-rpm-plugins-2.3.0-0.16.alpha.fc19.noarch
python-pulp-bindings-2.3.0-0.16.alpha.fc19.noarch
python-pulp-client-lib-2.3.0-0.16.alpha.fc19.noarch
python-pulp-common-2.3.0-0.16.alpha.fc19.noarch
python-pulp-puppet-common-2.3.0-0.16.alpha.fc19.noarch
python-pulp-rpm-common-2.3.0-0.16.alpha.fc19.noarch
python-pulp-rpm-extension-2.3.0-0.16.alpha.fc19.noarch
[bkearney@bkearney x86_64]$ ls /usr/lib/p
pkgconfig/ polkit-1/ pulp/ python2.7/ python3.3/
[bkearney@bkearney x86_64]$ ls /usr/lib/pulp/
admin/ plugins/
[bkearney@bkearney x86_64]$ ls /usr/lib/pulp/plugins/distributors/
iso_distributor/ yum_clone_distributor/ yum_distributor/
– bk
>> exception at
>> -- bk
> can you do a:
> rpm -qa "*pulp*" | sort
> pulp-rpm-plugins
> # rpm -ql pulp-rpm-plugins-2.3.1-1.el6.noarch |grep yum_distributor
> Mike
