Can you tell me how can I make a use of the Puppet module when it doesn’t have any classes and it is not visible from within the Foreman.
I downloaded the Puppet’s Inifile module for managing setting in INI files but it is not visible in the Foreman Puppet Classes. Of course I did try to import it from the Foreman server to the Foreman GUI, but it says that there are no changes and nothing is to applied.
So far I was using the Puppet modules with classes (via Smart Class Parameters, like NTP ) and I was attaching them to the Host Group configuration. Of course everything was working as expected.
How to make a use of the Puppet module when it is not visible in the Puppet classes? How I can attach it to the configuration of the provisioned hosts?
Foreman ver. 1.15
Thanks in advance!
