Using Puppet modules
Hi all,
I'm trying to use the Puppetlabs haproxy module (
https://forge.puppetlabs.com/puppetlabs/haproxy). Is it possible to use a
module written like this? I'd need Forman to output something like this:
node 'haproxy-server' {
class { 'haproxy': }
haproxy::listen { 'puppet00':
ipaddress => $::ipaddress,
ports => '8140',
node 'webserver01' {
@@haproxy::balancermember { $fqdn:
listening_service => 'puppet00',
server_names => $::hostname,
ipaddresses => $::ipaddress,
ports => '8140',
options => 'check'
Gareth
Gareth,
Foreman doesn't handle Puppet Resource Defines natively. More correctly, I
think the Foreman folks would say that Puppet doesn't allow the ENC to
define resources.
You will have to write a wrapper class which contains the defines. I
recently posted an example for another question on using
Razorsedge/puppet-network module.
Sean M. Alderman
Senior Engineer, UDit Systems Integration and Engineering
University of Dayton
salderman1@udayton.edu
"We are not some casual and meaningless product of evolution. Each of us
is the result of a thought of God. Each of us is willed. Each of us is
loved. Each of us is necessary."
- BXVI
··· On Wed, Apr 2, 2014 at 11:47 AM, Gareth Allen wrote:
Hi all,
I’m trying to use the Puppetlabs haproxy module (
a module written like this? I’d need Forman to output something like this:
node ‘haproxy-server’ {
class { ‘haproxy’: }
haproxy::listen { ‘puppet00’:
ports => ‘8140’,
node ‘webserver01’ {
listening_service => ‘puppet00’,
ports => ‘8140’,
options => ‘check’
Gareth
"Foreman users" group.
