Problem: /usr/bin/foreman-node:175:in `’: Must provide minion as an argument (RuntimeError)
If i am running highstate from foreman - the associated states will not be executed on salt-minion. cause the script foreman-node exits with error 1
All other things that are defined in env by top.sls will be executed without problems.
Expected outcome: highstate with associated states from foreman-ui
Foreman and Proxy versions: 2.4.1
Foreman
Version
2.41
Dynflow
Version
0.3.0
Registration
Version
2.4.1
SSH
Version
0.3.1
Salt
Version
3.1.2
Distribution and version: Ubuntu 18.04
Other relevant data: Salt 3003
Dear Community,
if a highstate will be initiated from Foreman - i receive following error:
/var/log/syslog:
ERROR ] Top function ext_nodes failed with error Command ‘[’/usr/bin/foreman-node’, ‘minion01.bla.ba’]’ returned non-zero exit status 1. for minion minion01.bla.ba
/var/log/foreman-proxy/proxy.log
Will run state.highstate for minion01.bla.ba Full command: /usr/bin/sudo -u root /usr/bin/salt --async minion01.bla.ba state.highstate
2021-06-28T17:55:18 08726a9c [I] Result: Executed command with job ID: 20210628155518016876
Best regards, Alex
Does the command work if you run “foreman-node minion01.bla.bla” on the foreman/smart-proxy manually?
Hi Bernhard,
yes, the command is working. if i am right, classes should be recognized by foreman-node to build the highstate in addition to top.sls?
classes:
- states.ntp
- states.users
parameters:
hostname: test
fqdn: test.bla.ba
hostgroup: Test
comment: Testmachine
foreman_subnets:
- name: test.test
network: 200.200.200.0
mask: 255.255.255.0
gateway: ‘’
dns_primary: ‘’
dns_secondary: ‘’
what do you mean by classes? the sequence you shared looks like grains.
i mean states, in the report output script it’s defined as classes.
classes:
- states.certs
- states.certs.ca-certs
- states.certs.certs
- states.certs.package
- states.logrotate
- states.knownhosts
- states.motd
- states.needrestart
- states.ntp
- states.rsyslog
- states.sudo
- states.users
- states.vimrc-root
i recognized - that my saltuser is unable to call the /usr/bin/foreman-node.
saltuser@foreman01:/root$ /usr/bin/foreman-node [foreman01.bla.bla](http://foreman01.bla.bla/)
Could not get grains: 765: unexpected token at ''
Couldn't retrieve ENC data: Could not send facts to Foreman: exit
root got no problems to execute the foreman-node.
did a new install with debian and guess what? same result. actually i am lost with foreman and the saltplugin. perhaps you got a hint for me?
2021-07-16 16:32:09,559 [salt.daemons.masterapi:529 ][ERROR ][39149] Top function ext_nodes failed with error Command '['/usr/bin/foreman-node', 'foreman01.uuxoi.local']' returned non-zero exit status 1. for minion foreman01.uuxoi.local
executing foreman-node with root:
root@foreman01:~# /usr/bin/foreman-node foreman01.uuxoi.local
classes:
- states.logrotate
- states.motd
- states.ntp
parameters:
hostname: foreman01
fqdn: foreman01.uuxoi.local
foreman_subnets: []
foreman_interfaces:
- ip: 192.168.0.30
ip6:
mac: 00:0c:29:06:f9:c0
attrs: {}
with saltuser:
saltuser@foreman01:/root$ /usr/bin/foreman-node foreman01.uuxoi.local
Foreman Output:
Best regards, Alex
Okay, i reverted to salt 2018 - now the logs are looking good for me.
3003-DS.1 seems to be Problem, are there any experience about newer version of salt in combination with foreman?
